Question about Denon AVR-5803 Receiver
No sound from surround sound - Denon AVR-5803 Receiver
I have rca DVD surround can I hook up so reg TV and DVD is surround sound both
you have to start with surround sound to get surround sound so no,but if you want sound out of the speakers on the surround sound from your tv,you can do that.
May 10, 2015 | RCA Televison & Video
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
How do u get surround sound out of all the speakers when watchen tv
Most of the time, you will only get surround sound out of all the speakers when the Soure (ie Cable, Satellite etc.) puts out surround sound. The receiver can only give what it gets (unless it has a simulated surround function, in which case it wouldn't be true surround sound). If you can check the info from the source, see if it shows you Dolby 5.1 or DTS as an option. If these aren't available, then you won't get surround sound. Hope this helps!
Mar 01, 2011 | Samsung HTC550 Theater System
No surround sound coming from tv. surround sound
It all depends on the TV transmission. If it is stereo, you will get the surround sound. If it is not then you have to listen to ordinary sound.
Dec 20, 2009 | Audiovox 150W DVD Home Theater System -...
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Tv surround
It depends on what you currently have as equipment.
You'll have to have something that outputs in digital audio (coaxial or optical). Either your reciever (Cable/Satellite) or the TV. You'll just hook that up to the Surround Sound unit and then just turn on the Surround System when you want surround sound.
You'll have to connect the TV as you would normally with audio cables sicne you'll want stereo sound on the regualr channels.
Nov 22, 2007 | Sanyo DWM-2600 System
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Open Questions:
Denon AVR 5803A upsampled digital inputs I had 2 questions you might be able to help me with. Both relate to my Denon 5803A signal processing. I have just purchased a Cambridge Audio Azur 840C CD player with both digital and analog outputs. The CD player upsamples standard 44.1 khz to 48, 96, 192 for digital output (and 384 for conversion in the CD player for analog output). The Denon is listed as having DAC's that operate at 192, yet when I upsample the CD digital output to 192, the denon switches to 'analog' from digital, and plays nothing through the digital coax input. If I take it down to 96khz, it plays (and lists as 96 PCM on the front panel when in 'auto' mode). So first question is how do I take a 192 khz digital signal into the Denon. I had thought the "A" designation/upgrade allowed for this. 2nd question - if I take the analog out from the CD player to the analog in on the Denon, does the Denon convert back to digital in order to 1) split the signal to the sub vs. the mains at 80 hz (or is/can this be done in the analog realm), and 2) play in 7.1 channel stereo (I know some signal processing happens for center channel, but I don't use this channel...so technically 6.1 channel). Net, does the left and right channels for front, side, and back have any signal processing in the digital realm on 7.1 channel setting. I ask because the CD player actually upsamples to 384 khz before converting to analog for a very good signal. yet I like a crossovered signal for sub, and enjoy 6.1 music at times. Thanks for any help you can offer.
Feb 28, 2017 | Denon AVR-5803 Receiver
Denon AVR-5803 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
