Question about Pool & Spa
Aquacal heat pump high pressure refrigerant fault
2 Suggested Answers
  • 990 Answers
SOURCE: HEAT PUMP SAYS WATER TEMP IS 99 DEGREES WHEN ITS
This is a bad temp sensor or an open by-pass. You would have to go to your book to find these though. I'm not sure where you would find them.
Posted on Oct 13, 2010
Heat Pump comes on, fans slow down, switches off?
Sounds like a bad temp sensor or switch. Like in cars my guess is that the switch is failing to work causing the fans to stop despite the pump getting hot.
Jun 23, 2014 | Aquacal ICEBRKR HEAT/COOL 110K TITANIUM...
How do i wire an aquacal 155 heat pump?
Contact a pool supply store or the manufacturer for manual.
Jun 03, 2014 | Aquacal Heat Pump Pool Heater 155
Heat pump problems
Some heat pumps have high and low pressure swiches installed to keep compressor from running when unsafe conditions occur that can damage the compressor. If the outside fan is not turing on, the unit is cycling on high pressure, if you see ice forming on the big refrigerant line coming from the air handler, then the compressor is shutting down on low pressure. Low pressure can be cause by lack of air flow through air handler or from a low refrigerant charge.
Feb 13, 2014 | Intertherm Heating & Cooling
Error code PO
overheated check gas pressure if not enough it will distort heat exchange
Jan 26, 2014 | Aquacal HeatWave
What does HP5 mean on my heat pump?
please refer to page 51 of this manual. http://aquacal.com/heat-pump-information/support/manuals/pdf/man-AT_HW_SQ.pdf
This explains that it is either due to your pump not pushing enough water.
Or the pressure switch is clogged or failed.
Or the wiring has shorted.
Check to make sure the circulation pump is not clogged and flowing freely.
make sure the filter is clean and flowing freely.
if this does not fix the problem, replace the pressure switch.
refer to page 56 for pressure switch identification.
Nov 18, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
HEAT PUMP SAYS WATER TEMP IS 99 DEGREES WHEN ITS 82 CAUSEING PUMP NOT TO TURN ON WHATS THE REMEDY NOT SURE ON BTUS MODEL NUMBER IS 120AHDEBNC AQUACAL kind of in a bind thanks
Oct 13, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
I have a AquaCal Heatwave H125C-A Pool Heater. The Heater is working in that the power is going on and the air is blowing- although- the air is usually colder than the outside air and now it is only air...
Sounds like your compressor is not running. After your fan goes on in one to five minutes you should hear the compressor kick in. If it does this and then kicks out again it can be something as simple as water flow and you can adjust the valves to get more or less flow to keep it running. If not you probally need a repairman. It is ether your compressor or the capicators that start the compressor and this is all high voltage. Good luck.
Jan 25, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool & Spa Logo
14 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
