Question about Sony DVP-NS575P DVD Player
Simple hookup instructions - Sony DVP-NS575P DVD Player
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Follow the instructions beginning on page 17 of this manual: http://www.fixya.com/support/p229787-sony_dvp_ns575p_dvd_player/manual-15814
Posted on Oct 10, 2013
How to hookup kenwood system w/receiver,cd/dvd etc HELP?
basic setup is simple
connect the kenwood an test it out with speakers
then get some cables to connect it to your tv
you need a cable or 2 , rca phono connectors likely
from the receiver video an audio out to the tv audio video in
you might have 2 sets on each
2 outs an 2 ins
it wont matta which you choose
turn the tv to aux or video input 1 or 2
May 03, 2015 | Televison & Video
Tip
How to Hookup Your Outdoor Wood Boiler
You just bought or a thinking of buying an <span style="font-weight: bold;">outdoor wood boiler.</span> How do you integrate that boiler into your existing <span style="font-weight: bold;">home heating system</span>? The guy selling you the boiler wants the sale and tells you that hooking it into your system is very simple.<br /><br /><span style="font-weight: bold;">Outdoor wood boilers </span>come in many shapes and sizes. For the most part bigger is better for these things. The next thing you need to consider is whether the <span style="font-weight: bold;">boiler is an open or closed system</span>. It does make a difference in the way it gets hooked up. <span style="font-weight: bold;">Closed systems</span> can be hooked right up to your <span style="font-weight: bold;">existing boiler system </span>in a <span style="font-weight: bold;">primary secondary configuration</span>. This means that the wood boiler circulates to two tees in your home system and the home system circulates the water through the home. The two waters mix through the tees.<br /><br />If your wood boiler is an <span style="font-weight: bold;">open system</span> then you need to install a <span style="font-weight: bold;">stainless steel flat plate heat exchanger </span>to divide the two waters. The hookup of the <span style="font-weight: bold;">heat exchanger</span> is not that hard if you follow the instructions properly. This heat exchanger is very effect in<span style="font-weight: bold;"> transferring the heat</span> from the wood boiler to the inside heating system. It also keeps the water of the<span style="font-weight: bold;"> inside system pressurized and isolated.</span><br /><br />If you are installing your outdoor furnace to a <span style="font-weight: bold;">hot air heating system</span> then you need to <span style="font-weight: bold;">buy a coil</span> similar to your car radiator to install in the plenum on the supply side of your <span style="font-weight: bold;">existing hot air furnace</span>. To this coil you will <span style="font-weight: bold;">hookup the water pipes from the outdoor boiler</span>. The water running through the coil will heat it up so that the air going through from the <span style="font-weight: bold;">hot air furnace </span>will be warmed. The water hookup for this style of heat is very simple, but the <span style="font-weight: bold;">electrical hookup of the blower, pump, and circulator </span>may not be as simple. You may need someone with a good electrical knowledge to make everything happen in the right sequence.<br /><br /><span style="font-weight: bold;">Outdoor wood boilers can heat your home effectively </span>if they are <span style="font-weight: bold;">installed to your existing heating system properly</span>. If they are installed properly you will notice no difference in the heating of your home. It will be <span style="font-weight: bold;">warm and comfortable.</span> Make sue that you do your research properly before trying to <span style="font-weight: bold;">install your outdoor wood boiler.</span>
on Feb 21, 2011 | Heating & Cooling
Tip
How to Hookup Your Outdoor Wood Boiler to Your Existing Heating System
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You just bought or a thinking of buying an outdoor wood boiler. How do you integrate that boiler into your existing home heating system? The guy selling you the boiler wants the sale and tells you that hooking it into your system is very simple.
Outdoor wood boilers come in many shapes and sizes. For the most part bigger is better for these things. The next thing you need to consider is whether the boiler is open or closed. It does make a difference in the way it gets hooked up. Closed systems can be hooked right up to your existing boiler system in a primary secondary configuration. This means that the wood boiler circulates to two tees in your home system and the home system circulates the water through the home. The two waters mix through the tees.
If your wood boiler is an open system then you need to install a stainless steel flat plate heat exchanger to divide the two waters. The hookup of the heat exchanger is not that hard if you follow the instructions properly. This heat exchanger is very effect in transferring the heat from the wood boiler to the inside heating system. It also keeps the water of the inside system pressurized and isolated.
If you are installing your outdoor furnace to a hot air heating system then you need to buy a coil similar to your car radiator to install in the plenum on the supply side of your existing hot air furnace. To this coil you will hookup the water pipes from the outdoor boiler. The water running through the coil will heat it up so that the air going through from the hot air furnace will be warmed. The water hookup for this style of heat is very simple, but the electrical hookup of the blower, pump, and circulator may not be as simple. You may need someone with a good electrical knowledge to make everything happen in the right sequence.
Outdoor wood boilers can heat your home effectively if they are installed to your existing heating system properly. If they are installed properly you will notice no difference in the heating of your home. It will be warm and comfortable. Make sue that you do your research properly before trying to install your outdoor wood boiler.
on Dec 03, 2009 | Heating & Cooling
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Need a password to hookup my Netbook Ebook Reader.want to hookup to WiFi
1. you have to setup the Netbook inside the router
2. the router CD will have the instruction set to add a wireless device to the wireless device list in the router configuration.
3. to reset a password for the router you will have to set the router to default and go through the setup wizard again to reset the password.
You router manufacture site will have the instruction site to assist you with this.
Apr 13, 2011 | Dynex DXWEGRTR Router
The cable hookup has fallen out of the panel in
You need to find someone to reinstall the connector. If I was closer it might be a simple repair. Email me at.... poikaa@yahoo.com
Feb 15, 2010 | Vizio VW42LF 42 in. LCD HDTV
I beleieve all the hookups are correct. I'm timer
Make sure the scart leads are fully in both on the vcr and tv,if they are not this can lead to no pic but sound or sound no pic
Oct 08, 2009 | Panasonic Televison & Video
No instruction how to hookup
Choose interface type usually USB cable don't plug anything into PC until you download driver for your model. www.hp.com support and drivers section, type in model and download file. When it is in the install process it will tell you when to connect the cable and turn it on. It will finish and you should be good to go.
Hope this helps,
TankMurdock
Apr 24, 2009 | HP 5510 4-in-one Printer
How to hookup Nintendo 64 to my 26" Westinghouse LCD HDTV?
You should know how to hookup the power, after that, you should have a second cord, one end goes into the N64, the other end splits up into 3 cords, one yellow, one red, one white.
Simple find the correct ports in your HDTV and plug it in.
Feb 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Connecting sony str/k660p to dvd recorder and tv
Hello jvirgil,
Go to http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK660P&LOC=3
and under the hot topics section, click on "Hookup Recommendation Guide", select the components you want to hookup (Dvd recorder and receiver in your case. TV hass been autoselected). Click continue, select all the different inputs/outputs that your components have, click on Recommend my Hookup and... 'voila' you get your personalized connection guide. Hope this helps.
cancerags
Dec 27, 2007 | Audio Players & Recorders
Sony DVP-NS575P DVD Player Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
