Question about Dryers
My fan motor is not working totaly - Dryers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
PROBLEM; My fan motor is not working totally!
So, i guess that your fan motor is working partially
because it is not working totally.
Please try to be more vague, if you posibably can be.
You will loose 10 points if you actually give any one an idea of what could be wrong with your fan.---ha-ha! sorry,it just seemed too funny to me.
Sounds like:----option #1------- your fan motor is either not running at proscribed speed (fer instance, high is not high enough or low is too low.) This is usually caused by lack of oil on the fan motor bearings.,easy to oil the bearings & dirt cheap too.
but could be caused by an almost burnt out fan motor.In that casethe Motor is not fixable, & needs 2 -B replaced, but dont bother to. It is cheaper to buy another fan at wal marts.
option #2
that portions of the 2 speed or 3 speed selector switch are not totally making contact.
or --option # 3, one of your motor windings could be burnt open.
So,let me start with --#3-- the worst case senarieo
Diagnostic proceedure for Dr. Fixit
You need to supply 120 volts ac in turn to winding lead #1, then to winding lead #2 and then to winding lead #3----
There are 4 wires on a 3 position fan speed switch.
1 wire for low speed,1 wire for medium speed and 1 wire for high speed. This looks like the letter Y with each leg of the Y
[ around the outside of the Y ] being one speed winding. THe neutral return wire would hook up to the center of the Y and this would give you your 3 circuits, depending on which outside leg
that the speed selector switch selects. lo,med or hi--- the neutral return wire at the center of the Y will compleate the circuit, one winding at a time ,depending on speed selector switch setting, for all 3 speeds.
All 3 speed windings need to work for the fan motor to work totally.
If one speed winding is burnt open, the fan motor will only work partially, 2/3rds ,that is. You can still use the fan by cutting off the lead of the bad speed winding and using the other 2 windings.
If 2 wings are bad and dont run, the fan will still work partially with only 1 speed.
If you have no-- or intermittant contact on your fan speed switch,
you will have to order a new replacement switch. This is assume-ing that all 3 speed windings worked properly at their respective speeds , when you tested them earlier , with the speed selector removed from the circuit for testing of the motor windings to see if they each work with the selector switch out of the circuit
If you know that all 3 speed windings run ok , with the selector switch cut out of the circuit, then you know that the speed selector switch is bad.
Firstly,unplug the fan from the electricity so that your hair does not stand up on end, which would surely be a shocking experience.
secondly,
remove the old speed selector switch, noting down on paper, what color wires go where and put the same color wires from the new switch back in the same place that that color wire of the old switch came off of.
(i know this sounds funny, but it really totally works.)
use electrical tape and/ or wire nuts to make electrical connections, if necessary.
With the new switch installed, the 2 or 3 fan motor speed settings will now totally all work.
most electric fans have steel rotor shafts with bronze bearings.
they "call" them oilite bearings,susposedly because the bronze bushing (it is really a bronze bushing) but called a bearing, is oil impregnanted and susposed to be good for the life of the fan.
that is only true if you expect the life of the fan to be ONLY 18 to 24 months which is the average time that the factory oil lasts.
the oil dries up the longer the fan runs and the shaft makes the bronze bushing begin to heat up due to increased friction and eventually wear the round bronze bushinhg egg shaped.
Try giving your bearings a good healthy squirt of sae 30 wieght oil from a zoom spout-- [pull out straw squeeze bottle refillable oiler.]
I recommend oiling both the front and real fan motor bearings once a month.
This is the most common cause of fan failure.
Because I oil my fans bearings once a month,I still have fans that run from 1940,1950,1960 and 1970. The 1940 GE fan lasted 70 years and is still running strong.
Some newer fans have chinese ball bearings , but the ball bearings also die prematurely from lack of needed oil.
Sometimes, you can pry off the bearing race cover to get oil into the bearing.
a good trick here is to use wd40 if you think you cant get sae 30 into the bearing.
wd40 is a n extreemly light wieght oil that penetrates very well
and gets into places where you think it wont get into .
You can totally wet up a fan motor with either
sae 30 or wd 40 or both without worrying about the electric
motor being harmed by the oil.
the oil,sae 30 or wd 40 wont hurt the motor.
On badly rusted and nearly siezed fan motor bushings , or any electric motor as well, I use first wd40 for penetration and then sae 30 for good long duty lubricatin.
You may have to keep squirting ioil in the motor for 1/2 hour and end up with a puddle of oil under the fan motor, but about 40 % of the time ,you can bring back to life what yo thought was a dead motor. Perserverance is required and faith that you can fix the motor. 40 % of the time you get sucess to one degree or another and 60 % of the time ,its kaput for good.
I got all those fans i mentioned before because other people thought the bearing were seized and shot, and put the fans in the garbage pail where I rescued the fans from.
the bearings were almost siezed but far from shot becaue i got oil in to the shafts and bearings and another 12 to 20 years of life from the fans. However,i do oil them monthly in fan season, which is winter time for me, since I use fans to blow the hot air off of my wood stove.
Posted on Oct 11, 2013
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
May 20, 2014 | Maytag Ice2O MFX2570AE 25.0 cu. ft. French...
Do I clean model FS10-S4R the same as model FZ10-9HB have had this for a long time really needs cleaning bad it is a wonderful fan
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 27, 2012 | Tower Aloha Breeze Fan
How to clean
Jan 14, 2012 | Lasko 3300 Wind Machine Fan
Pure pro fan motor
Jan 12, 2012 | Montgomery Ward Pure Pro Air Purifier
Need a wiring diagram for this unit. Its a friends unit,he says that in cooling the outdoor fan stops running with compressor running I suspect a bad relay on defrost board (it want do it while I'm...
the outdoor fan should not stop while compressor is running and I would first suspect that the outdoor motor is bad - I would feel the motor with my hand (after it stops/with all electrical power turned off) and see if it was 'hot' to the touch.
If it is - then the motor is 'electrically breaking down' and will need to be replaced.
There is a slight chance that the fan motor capacitor (small silver/grey device) which is hooked to the motor by electrical wires - is bad - but I doubt it. Even so - if the capacitor has a visible bulge then I would first change the capacitor before the motor.
I would never change one circuit board for another unless it was an exact replacement for the one I was changing and included instructions on how to wire.
I seriously doubt that the problem is in the circuit board.
Aug 05, 2011 | Heating & Cooling
Tried changing keyboards , different usb ports, tried to restart totaly dead now, had to jump,running[fans only] lights on 2&3,still says keyboard failure. Time of day clock stopped . Invalid...
REPLACE THE LITHIUM BATTERY ON THE MOTHER BOARD IF THAT DOESN'T HELP LOOK AT THE FAN IN THE BACK OF THE POWER SUPPLY TO SEE IF THE FAN IS SPINNING IF NOT YOU WILL HAVE TO REPLACE IT
Jun 25, 2011 | Dell Dimension E310 PC Desktop
Both fridge and freezer have stopped cooling and in fact the ice maker began giving off immense heat. The compresser is very hot as well and have had not issues with the fridge until sometime today.
I suggest you switch the fridge off immediately and defrost totaly for 12 hours. Very possibly the door has somehow been opened slightly by mistake and moisture has found its way onto the evaporator plate. This will either stop the evap fan motor from running and or totally block the evaporator which will inturn give you the results that you are experiencing now. After total defrost, switch on again and listen for the fan motor which comes on once the door is closed. Normally all should be good.
Aug 29, 2010 | Refrigerators
I have a 5 speed forward minn kota only 3 speeds work ,I replaced the speed control box but have the same problem
Check the Relay's these will be found in the control module, Most likely totaly sealed, test or replacement may be required
Aug 26, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
The overheating problem I'm having with my 2002 impala has me totaly stumped. I feel i've checked and/or replaced everything from water pump to radiator. even to bypass the heater coil. what can be causing...
Make sure the electric fan if equipped is coming on after 10 - 15 min. of operation if not replace the fan relay. Make sure antifreeze/water is a 50/50 mixture, If the fan relay doesn't do it replace the fan if the car has no electric fan the clutch fan may be faulty if equipped.
Jul 27, 2009 | 2003 Chevrolet Impala
Dryers Logo
174 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
