Question about Canon LaserClass LC 8500 Plain Paper Fax
What ink or toner cartridge would I use for a Canon mf8500c
5 Suggested Answers
SOURCE: Toner Cartridge
Mine is a single cartridge system. The black cartridge that looks like it holds the ink is the toner cartridge. Replace it with cartridge E40.
Posted on Sep 30, 2008
SOURCE: canon x25 toner cartridge
Don't try and refill this on your own, you'll only have difficulty. Buy a reasonably priced compatible, that is "remanufactured" -not 'refilled'. It's not just toner that makes it work. The drum, cleaning blade, and doctor blade (at minimum) need to be replaced for proper operation, and there is also a toner waste hopper that needs emptying or it will overflow on second cycle.
Just my 2 cents.
Posted on Mar 31, 2009
  • 1126 Answers
SOURCE: How to install toner cartridge in a Canon 920
On your Canon PC 920, there is a recessed gray latch located on the left side of the machine towards the top front...press upwards on this latch to release the top part of copier (same as removing a misfeed or clearing a paper jam). The copier opens up.....now, located in the top unit, about center, is the drum / toner unit. It has a black plastic handle on it. Grasp this handle and pull towards you...slowly...until it is free of machine (support the rear of the unit with your other hand) Open new cartridge (unit) and install in reverse order (there should be instructions with the new cartridge) The copier has rails that the cartridge mounts on. Another note, before installing....gently shift the cartridge from side to side.....this distributes the toner evenly (again, covered in the installation instructions packed with the cartridge) There is a tab that needs to be removed to allow the toner to get where it needs to go for copying....attatched to this tab is a strip of plastic, pull all the way out. I have a PC 940...it uses the same cartridge.
Posted on Mar 24, 2010
Testimonial: "Thank you. Asking for a person who was given this photocopier without a Users Manual. He was pleased to have the instructions and wanted to say Thanks"
  • 32 Answers
SOURCE: I replaced the black toner
i think u r using compatable cartridge replace in to original one or u r developer will be damaged
Posted on May 12, 2011
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
No ink reset on Canon BJ S750 Printer
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 11, 2010 | Canon Office Equipment & Supplies
I changed my Canon PIXMA MP780 3e cartridge, and
Don
Mar 10, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon mp620 put in new ink for the first time and it doesn't work
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
Don
Feb 21, 2010 | Canon Office Equipment & Supplies
My printer doesn't print anything..I put a new ink cartridge. I have a canon i320.
Don
Feb 17, 2010 | Canon BubbleJet i320 Printer
Printer is sounding like it is printing but paper comes out blank
I think the ink of the toner is finish or toner is not place at right situation. Please check toner ink and position of the toner.
Sep 24, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma 470/ cyan and yellow won't print
it may be many things, here some thing to try:
the ink or toner is contrammed with foreign liqued like oils, water, bad ink, bad toner cartridge,
oil, water, ink toner inside the ink itself
oil from a human skin my have came in contact with refill of ink or toner cartridge, cleaning solvent to clean the cartridge, needles for hte ink or toner cartridge, water in the ink or toner cartridge, steam or vapors of some kind, compress air can or air compressor will spread water solution, the freon is used in compressed air can thats way they get so cold when you spray the can.
paper may also be wet some how try new and different brand of paper.
rod the candymangandy
Feb 04, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Toner Cartridge
Jun 12, 2008 | Canon PC-920 Black and White Copier
Toner
when they say TONER , its refering to the INK CARTRIDGES , Color & black ,
CANON PIXMA MP780 & MP750 uses the same INK CARTRIDGES :
BCI-3eBK for BLACK & BC-31C for color
please rate this solution , hope this helps
May 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon LaserClass LC 8500 Plain Paper Fax Logo
369 people viewed this question
old marine
old marine
