Question about Homedics Digital Scale
Glass on digital broken Can it be fixed
How do I change broken glass in 7024W?
do you mean a place that will fix it for you or are you planning on DIY repair. If you want to take it somewhere you could contact the manufacturer of the phone.
http://www.alcatelonetouch.com/global-en/support/faq/service.html
if you are planning on DIY it is real easy to damage the digitizer under the glass when trying to replace the glass. You can buy replacement glass but you need to heat up the glass to the point that the glue melts and the digitizer underneath does not burn. you have to lift the glass gently and bit by bit without putting pressure on the digitizer. suggest looking at Utube videos on how to replace glass on various mobile phones. If the digitizer is already damaged you have to replace the digitizer which is costly and involves pulling a mobile phone to pieces and re assembling it.
Jan 20, 2015 | Cell Phones
Broke screen iphone 4
No. The digitizer and lcd and everything is one piece in the iphone 4. You have to replace the digitizer and all. Which means you do have to take the iphone apart.
Feb 05, 2013 | Apple iPhone 4 Black Smartphone
My drivers side rear window is off the track and i believe the cable is broken because i cant re-latch it to where it goes. how do i fix this?
WINDOW GLASS REGULATOR BROKEN OR GLASS TO CHANNEL NUTS LOOSE AND MISSING.YOU HAVE TO REMOVE DOOR PANEL FIX WINDOW GLASS.
May 31, 2011 | 1999 Oldsmobile Alero
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
Is it possible to fix the view screen if just the glass (not the ldc) is broken? Fuji FinePix Z5fd
There is a plastic cover over the LCD. Is only the cover broken? The plastic cover is easily replaceable.
But there is also a sheet of glas over the LCD. This is a part of the LCD assy and cannot be replaced without replacing the entire LCD.
Feb 08, 2010 | Fuji FinePix Z5fd Digital Camera
My i735 Camera wont show any images. When I turn it on, the screen looks like broken glass
if it looks like broken glass then probably the lcd screen might have raptured internally. does it glow or seem to switch on ?
Mar 02, 2009 | Polaroid i735 Digital Camera
Broken ts
yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
Dec 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Homedics Digital Scale Logo
20 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
