Question about Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature
Hi my my maytag oven part no 10243032 wht is
Hi my my maytag oven part no 10243032 wht is locked please tell me how to unlock it
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Oven door is locked how do you unlock it?
    hi
    unplug the oven from the wall
    and repug it
    it will be reset and let you open the door
    Jan 09, 2011 | Maytag Ovens
    New oven just locked upa and won't iopen while baking
    Hello,sometimes the oven lock wont unlock until the oven has completely cooled
    Thanks
    May 23, 2010 | Maytag CWE4800A Electric Single Oven
    Cleaned bottom oven. Top oven door won't open
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
    Maytag gas oven lock does not release
    Unplugging it for a few minutes may reset it.
    Sep 28, 2017 | Maytag MEW5530D Electric Single Oven
    MY OVEN IS LOCKED
    unplug the oven wait 5 minutes and plug back in usually that resets the controll panel then it will unlock
    Jan 21, 2010 | Maytag MEW5527B Electric Single Oven
    Maytag double oven is locked and won't open
    Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
    Hope this helps.
    David
    Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
    I CAN'T UNLOCK MY OVEN DOOR!
    First get rid of the noise by turnining off te breaker.
    You will have to pry the lock open.
    This is common I use a small screwdriver and coathanger wire,then pull out oven enouhg to replace lock.
    Mar 12, 2009 | Ovens
    Oven door locked and i have no idea how to unlock.
    its not locked its got cracked internally.so it not getting opened and showing locked.click the link and check out http://www.applianceaid.com/micro2.html
    Mar 09, 2009 | GE JKP15 Electric Single Oven
    Oven is locked
    press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
    Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
    Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature Logo
    13 people viewed this question
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
