Fan motor smokes on medium speed. - Heating & Cooling
    Scholar:
  • 111 Answers
If you have a motor that is smoking that is not a good thing, sounds as thought one of the windings are going bad, I would highly recommend replaicing versus any kind of repair.
Posted on Oct 11, 2013
Gentlemen, I have a GE P547BS fan motor.I'm trying to replace it with a Mars 10584 fan motor.
You can check the colors on the wires with an ohm meter to find there function. Highest resistance is low speed lowest resistance is high speed the one left is medium.
Aug 25, 2015 | GE Heating & Cooling
Fan will only blow on low when heat is on
your fan most likely is wired for low speed for heat which is common. this should be determined when furnace is set up properly. motors that aren't modulating motors and are multispeed motors typically have low medium and high taps that come off the motor and go to the corresponding relay on the board. low and medium speeds are used for heat and high and medium speeds are used for cooling. but only one speed for heat and one speed for cooling many times medium never gets used. im not familiar with klimaire is this a mini split system and not a regular air handler. cause speed control should be adjustable from the remote. if its a split but if not reaching desired speed due to a malfunction in the units could cause it to run low speed just to maintain the temperature exiting the indoor unit.
Oct 21, 2013 | Klimaire Heating & Cooling
Replaced fan switch but fan only works on low and high but not work on medium
You have a problem with the connection to the medium speed motor winding, or a problem in the motor. Turn off power to the fan, open it up and verify that the wire nuts are properly installed.
Nov 14, 2011 | Hunter 52" Ceiling Fan With Light And...
Noise problem CXL52WB
mcdevito75 here, From the little I know about these ceiling fans, they are a sealed bearing type motor, you may be hearing a dry bearing on medium speed for which you"d have to replace the fan to fix. Or, you may be hearing vibration of the fan itself when it"s on medium, vibration could be the fan itself or something slightly loose. Have a handy man take a look at the fan and it"s hook up, make sure everything is tight. Hope this helps.
Jul 19, 2010 | Craftmade International Craftmade...
Heater fan only works on "high speed"
All cars are designed with a blower fan motor that pushes air through the ventilation system. This air is processed by a series of vents to direct the air to various positions. Example: heater, air conditioner and defrost modes. Most blower motors are power by a basic electrical circuit that utilizes a multi resistor or a solid-state resistor to control different fan speed modes (low, medium low, medium and high). If the resistor malfunctions it may lose one or more of the lower fan speed settings.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Mar 02, 2010 | 1999 Buick Century
A/C Control Dail only works or High. Replaced a/c compressor.
The A/C dial is High Medium and Low, that only changes the fan speed, it doesn't changed the compressor at all, with all three speeds.
If the fan is not running the compressor won't run very long.
Probably an open winding, in the medium speed of the motor, the switch is bad or medium and low speed not hooked up.
Aug 22, 2009 | Heating & Cooling
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
3 speed switch wiring schmatic
On a 3 speed switch you usually have 4 terminals, and they are marked L1, 1, 2 and 3.
L1 which is line voltage from the electrical cord or wall plug, #1 low speed usually a red wire from motor, #2 medium speed usually a blue wire from the motor and #3 high speed usually a black wire from the motor. That is if the fan is low,medium and high, if it says high, medium and low then reverse #1, #2 and #3
May 08, 2009 | Heating & Cooling
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Wiring a retrofit soft start blower into a Ruud 5T/100k gas pack
Chances are, you've smoked the motor. You basically put 120 volts across the speed windings of the motor when you did this.
What you need to do is, with the new motor, you will have neutral, and speed 1, speed 2, speed 3, etc. Hook one of the original black wires to neutral (it would be best to trace which of the two black wires is connected to neutral, and connect this one.).
Black on the new motor is probably High speed, red is probably low, orange is medium speed. Hook the remaining black wire to one of these, and no more than one of these, or you will smoke the motor again.
Attach a wire cap and/or electrical tape to the remaining wires to insulate them from contacting anything else.
Jan 27, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
