Question about Fujitsu fi-6130 Flatbed Scanner
Irregular status is detected in scanner - Fujitsu fi-6130 Flatbed Scanner
3 Suggested Answers
TechSatya
  • 104 Answers
SOURCE: fujitsu 4750c Irregular status is detected in
If "Front Side Optical Alarm" appeared, clean the glass (small and large one) of the flatbed and carrier unit.
If the issue persists, then check if CCD harness or CR cable is disconnected? Connect the connector.
If the issue persists, then replace Front lamp.
If the issue is not resolved, then replace the Control PCA or Carrier unit or Optical unit.
regards,
Tech Satya
Posted on Feb 09, 2010
john_madd112
SOURCE: Fujitsu fi-5750C flatbed will not scan. I keep
Mine came with the same error message. If you look through the glass into the left front corner, you should see a spring loaded belt tensioner device. It merely hooks into the bottom plate against a spring to keep the belt tight. On my 5750C, the belt tensioner had slipped out of the base during shipping. The hardest part of inserting it back into the base was getting to it. Directions to do that are on this site at .../support/t484836-taking_apart_flatbed.
Posted on Nov 15, 2011
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750C flatbed will not scan. I keep getting an error "Irregular status is detected in the scanner. Anomaly in Flatbed motor operation. There are some codes: Sense Key = 0x4; ASC=0x580;...
Sep 20, 2011 | Fujitsu fi-5750C Flatbed Scanner
We are not able to get our Fujitsu fi-5120C out of status 8. We've turned it on/off unplugged it changed one of the pads (as it was bent). We left it alone for a day and it's still not working. Do you have...
Thank you for contacting FixYa.
Please clarify if the error is E8 or some different error. E8 error indicates that SCSI fuse is blown. When 5V, 3.3V fuse is blown, the scanner does not turn on and E8 error is displayed. Check the SCSI fuse status. The SCSI fuse is located in the Control PCA marked as TH2. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable. #Check the SCSI cable status.
- Other SCSI device malfunction. #Check the SCSI device.
1. Does the same symptom occur after turning OFF and ON the scanner?
To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check if the SCSI cable or other SCSI devices connected to the scanner cause this error. The scanner can work even after this error occurs. However, to remove this error you may have to replace the Control PCA.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Microsoft Word - P1PA03289-B30X6_03.doc matsubara 11.9999 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Jul 15, 2010 | Fujitsu fi-5120C
Scanner not detected
I have the same problem with my Canoscan LiDE 25 scanner used sparingly since purchase in 2008. Last used 3 days back after a gap of a few months when it scanned a few pages and then stopped working. On connecting the scanner to my laptop on Vista Home Premium 32-bit it shows "USB device not recognized". No change in status after uninstalling drivers, cleaning my system, and reinstalling drivers from the Canon CD, or Canon US site, or Canon UK site. Even tried VueScan but this also does not recognize the scanner. I find it hard to believe that a Canon product stops working in barely 5-6 years even though it is very sparingly used and stored in the original packing when not in use.
Jul 03, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Blinking lights, ''offline'' status - hp deskjet d2360
If it used to work, then try unplugging and reconnecting the AC power cable for USB scanners. No guarantees at all, but it may work. Unplugging and reconnecting the Firewire cable in XP also sometimes works. Give it a few seconds to be detected.
Jan 05, 2010 | Office Equipment & Supplies
Fujitsu 4750c Irregular status is detected in scanner
regards,
Tech Satya
Sep 21, 2009 | Fujitsu fi-4750C Flatbed Scanner
My hp clj 2600n printer wont stop reading initialzimg on control panel machine not spinning
This is the Power On Sequence
Power-on sequence
The power-on sequence is for the purpose of the printer initialization and checking for possible malfunctions.
The following is the sequence from when the printer is turned on until it enters STBY mode.
  1. Power on
  2. Central processing unit (CPU) initialization
  3. ASIC initialization
  4. Video interface communication start
  5. Residual paper check by each sensor signalling paper presence
  6. Initial drive for main motor, pickup motor, and fuser/delivery motor
  7. Fuser heater initial drive by controlling fuser temperature targeting for 100°?C
  8. Initial drive for scanner motor
  9. Failure/Abnormality check
    • Detect scanner failure
    • Fuser failure
    • Door open during the above periods
  10. Communication with memory tag
  11. Cartridge presence detection
Main motor failure detection
The CPU determines the main motor failure, stops the printer, and notifies the formatter of error
status, when it encounters the following conditions.
  1. Main motor start-up abnormality.
The interval of the MAIN MOTOR SPEED DETECTION signal (/MAINMFG) does not become the specified interval after 1000 ms of the main motor drive start.
  1. Main motor rotation abnormality. The interval of the /MAINMFG signal stays at an irregular interval for 100 ms and longer after once it has become the specified interval.
Fan motor failure detection
The CPU determines the fan motor failure and notifies the formatter when it encounters the following
condition.
The FAN LOCK signal (FANLCK) is “H” for approximately 10 seconds and longer during fan motor
rotation.
Your description makes it sound as though the printer has a main CPU failure as all other faults should display an error or error code. In the light of this it seems that the printer will need to be looked at by a service engineer asap.
Sep 21, 2009 | Office Equipment & Supplies
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-6130 Flatbed Scanner Logo
329 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
