Question about Homedics Garden
I have a bubble lamp that needs a replacement motor and it is a Homedics Model: P-12-3 Volt: 12V/60Hz Watt: 1.5W. Is this available as I really like my bubble lamp that changes colors.
2 Suggested Answers
SOURCE: I need new air pump for Homedics Aquascape twist
I have an older & slightly different 4 sided tapered Homedics aquarium, but it has the same pump. I used a meter to determine that the proper voltage was coming out of the transformer, measured at the plug. I took the base apart & bypassed the female connector switch the transformer plug, plugs into. Everything worked fine, meaning the fail was in the female connector, as the wires were solidly soldered on. With a magnifying glass, I could see that a rectangular "C" type copper flange, had the side that touches the side of the plug when inserted, had broken off, therefore making no connection. Using an insulated screw driver, I temporarily completed the circuit & confirmed the problem. Cut out the old female connector & take that & with the transformer (& its plug) to an electronic components store & find a suitable replacement. You will need additional heat shrink tubing & to solder the connections.
If your pump is truly not working even if it is getting power, I don't know the answer the full answer to that. A privately owned aquarium store may test the pump for you, & offer to feel or replace the diaphragm & check valves if the motor works. I see the screws are painted with locktite after re-assembly so the parts don't vibrate loose. Good Luck.
Posted on Nov 16, 2011
I have a 6000 watt allpower generator that the 12 volt breaker poped out reset it still no power replaced the avr ran for about 5 seconds then poped the 12 volt breaker again what could it be
Barry,
The 12v system does not go through the AVR. It most likely is the Battery Charging Rectifier has failed. This controls the voltage from the 12v feed from the alternator and charges the battery.
1) Follow the wiring from the 12v socket/connectors until you come to a Block rectifier. It will be held on by a bolt in the center and have 4 wires connected to it. If you look at the pins you will see one is seated at a different angle to the others. Test the feed to this pin, you should get a result of between 12 Volts DC to 16 Volt DC.
If you are not getting these results then the Block rectifier has blown and will need replacing. http://www.generatorguru.com/rectifier-98406168/
2) If all is testing fine above, then you will need to test the Battery Charging Rectifier as you have an Electric Start and Battery on your unit. This is a metal block located on the back of the engine, next to the starter motor and it has fins running across it. ( to see an example of this part look up your generator on this page http://www.generatorguru.com/all-power/) Again this should be giving you between 12 Volts DC to 16 Volt DC.
3) Next,check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC.
For replacement parts please see our web page. You will need the full model number to do this.:
Dec 06, 2016 | Allpower Electrical Supplies
I got a class to transformer power cord 120v AC 60hz 12 watt input output is 12 volt DC 6.0 what will that work on my Polaroid tDX 1930 B
Check Amperage of your Polaroidd and the power adapter. Same voltage but higher amperage might fry your Polaroid.
If won't work, you might buy one for Amazon
UpBright 12V AC Adapter For Polaroid TDX 01930B TV DVD Combo Charger Power...
May 12, 2015 | Computers & Internet
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
We have a lutron nova 2003p (1600 watt) switch supplying power to a line of 18 12 volt, 50 watt lamps. switch went out. is this caused by over-amperage draw?
Hi John, I'm an electrician and I think I can help you with this problem.
First and foremost, this switch's 2000VA / 1600W electrical rating is based on a incandescent load.
Let's do do the math on this one.. 18 x 50 = 900 watts. So, you're under the 1600 watt capacity, but I think this is a bit more involved than this.
I'd be willing to bet that you're not dimming a 12 volt circuit - but rather a 120 volt circuit that supplies one or more transformers that step the power down from 120 volts to the the 12 volt bulb voltage. A transformer is an inductive load. A transformer's inductive load is completely different than the incandescent load the dimmer is designed to control. The transformers are rated for 120 volts and will have issues including heat problems if provided less than the rated input voltage to provide a reduced output voltage you want so that you can dim these lights.
This switch will not work on the output of the transformer in this situation either because the significant amperage being switched here. Each of these lamps draws a bit over 4 amps as determined by ohm's law: 50W / 12V = 4.16A. The total load at 12 volts is (again, Ohm's law) 18 x 4.16A = 74.88A ! That means the wire would need to be a #4 or #2. This is about the size of the cable on your car's battery (only amperage determines conductor size - voltage determines insulation).
A dimmer on this circuit will not work unless the fixtures are changed so that no transformers are used to supply the lamps. This includes fluorescent lamps (compact or otherwise) unless the packaging specifically states that they can be used on a dimmer.
You may wish to contact Lutron Hotline at 800-523-9466 for additional help and suggestions. I hope this helps & good luck!
Mar 29, 2012 | Lutron Electrical Supplies
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
There are 4 pins on my maruti wiper motor. how do i run it using a 12v battery?(connections?)
one is a ground and the other 3 are speeds. all you need to do is put a 50 watt bulb in series with the 12 volt line,so that if you short to ground,all it does is light the bulb,not burn wiring etc.a car battery can put out a couple hundred amps or more.a 50 watt bulb limits the current to 5 amps,and it is enough to run the wiper motor...cheers
ed
Jul 11, 2009 | 1997 Chevrolet S-10 Pickup
Garden Logo
98 people viewed this question
Top Homedics Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Homedics Garden Expert? Answer questions, earn points and help others
