Question about Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT
I struck an object while mowing my yard and the tractor wont start or even crank what could the problem be?
  • Bernhard Flug Oct 10, 2013
    There are safety switches that will not allow anything to energize, (1) Blade/engage/disengage, (2)deck up position (3) seat must be on the seat (4) must depress break/cluch
  • Paul Gutierrez Oct 12, 2013
    The ignition switch just happened to fail.thanks for the input.
    Problem Solver:
  • 9 Answers
Start by disengaging the blade and putting the deck to it's highest position, prior to attempting to start the mower inspect under the mower deck making sure there is no Debee wedged interfering with the blade rotation, check your spindle's for play and inspect your mower and drive belts. once complete than give it a try. if by chance it does start but turns over you more than likely sheered the flywheel key.
Posted on Oct 10, 2013
  • Paul Gutierrez Oct 10, 2013
    it wont crank at all no clicking no starter engaging zilch nothing at all.
Troy-Bilt Colt XP. Start engine and begin mowing and everything is fine. After a few swipes on the yard, 2-3 minutes, PTO shuts off. turn off and back on works shortly. PTO clutch getting hot???
electric pto clutches get HOT (not warm) for only a few reasons
(1) worn out friction disks inside
(2) foreign object(s) not allowing clutch to fully engage a good blast of high pressure air knocks out most stuff , if let go to long this leads to 1st reason
Jun 29, 2015 | Garden
Mowing yard and stopped to go inside. Come back out and mower turned over but would not crank. Kept trying and it started clicking. Rocked the mower and it started. now does same thing but won't start
Check your charge in the battery. Clicking usually is dead battery. If the battery is good, starter may be bad (or at least the starter solenoid).
May 04, 2015 | Garden
Ok so the problem,on my gravely zt 2250 is was mowing went to shut blades off and they kept on spinning and there also spinning when trying start engine replaced clutch twice still same problem
Sound like either the PTO relay is struck in run position or the PTO switch has failed and applying 12v to the PTO relay even in the off position.
IPLs for the Gravely ZT2250
Wiring_Diagram/10265/10261
Nov 24, 2014 | Garden
Cub cadet 1515 won't start
I just had the same problem. I installed a new spark plug, sprayed some starting fluid in the engine and it started right up. I mowed my entire yard, and my neighbors yard with no problem?? I'll post more next mow and let you know if it has fixed the problem!!
Apr 29, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Smokes when i crank it up and when i engage mowing lever. Smokes from exhaust. just bought mower. It is a lts 2000 09' model. Bought from sears, mower was shortly owned and used.
what moter do you have on let me know ok hey ck the oil it may be over full it wont hurt it you just need to get the level right let me know
Oct 04, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Sep 12, 2008 | Garden
Poulan Pro 46Inch 22 HP Yard Tractor with Briggs and Stratton Engine PB22H46YT Logo
102 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
