Refrigerators Logo
Posted on Oct 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I access the control board? - Maytag Refrigerators
Richard Roth
Level 3:
Top Expert:
  • Maytag Master 9,472 Answers
  • Posted on Oct 12, 2013
Richard Roth
Maytag Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626590
Points
28464
What is your model number?
2answers
1helpful
Oven displays code F7
The F7 error code on this oven indicates that you have a problem with the control keypad or the electronic oven control board. The image below shows how to access the control board on this oven. Shut off the circuit breakerto the oven before accessing internal components. If you are able to access the control board, you can check the ribbon cable to make sure that it is properly plugged in. If the ribbon cable is secure and you see no damage to it, I recommend that you unplug that cable and reassemble the oven. Reset the breaker to power the oven back up. Wait for one minute to see if the F7 code returns with the ribbon cable unplugged. If it does then the electronic oven control board will need to be replaced.
Kenmore elite oasis washer, top load that flashes F1 at the rinse cycle, what part do i need to fix this???
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
The first image below shows the method for accessing the pressure transducer tube that runs from the bottom of the washer tub to the machine control. I recommend checking this air hose for pinches, twists or crimps.NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below. The part number for the machine control board is W10189966.
Image 1
Image 2
1helpful
Kenmore Elite Smartwash Quiet Pak 9. Washing bedding on "bulky/bedding", washer beeps, get error code F then 11. Messed with it a bit, now in Control Locked. Yikes. Help! Robin
Washer will suddenly shows the F11 error code...at times it may show the FdL code. The washer will then not finish no matter what I do. If I unplug the unit from the outlet that does not guarantee that when I plug it back in it will start up. Fifty percent of the time it still shows the F11 error. It can take hours to finally get the washer to cancel out so I can take the laundry out that has not been spun out.
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
The diagnosis of this failure usually requires a technician. If you are able to unplug the washer and safely access the central control board and motor control board, you can check for a loose wire harness connection. Beyond that, I recommend calling a service technician to diagnose and repair your washer. The location of the internal washer components and component access for the central control board and the motor control board are in the images below.
2helpful
F1 flashes half way through the wash
Hi...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this IMAGE...
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Kenmore elite he3 dryer says PF
The PF and E2 (F02) error codes are related. The PF indicates that the dryer is experiencing a power failure. The F-02 error code indicates a Keypad/User Interface failure. The error codes for this dryer are shown in the third image below.
You could have a loose wire harness connection between the machine control board and the user interface control board that could cause there error messages and symptoms. The first image below shows how to access these components. I recommend that you unplug the dryer and then access these components. Check the wire harness connections on between the user interface control board and the machine control board. If the connections are okay then you will likely need to replace the user interface control board to correct this problem. The part number for the user interface control board is 8564396. You can order this part from the Sears PartsDirect website. It costs just over $100.
How do you gain access to the Front Panel circut board? On a Jenn Air JDB8910AWW Dishwasher? If I want to check the soldering connections, I don't want to open up areas which would make more work for me....
the front panel control board is accessed by taking off the inside door panel that will release the control panel so you can get to the control board but do not try to solder connections on the board just replace the complete board
Apr 03, 2010 • Dishwashers
1helpful
Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
LCD controller board location on Vizio L37
Display controller is usually under the Main board which you remove to get access to it. Display controller connects to the suis-boards which then send signal to the screen of the TV.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
