Question about Garden
I need an instruction manual for makita chain saw DCS34
  • 30 Answers
You can purchase one from store.payloadz.com most manuals cost $ 8.99. hope this helps
Posted on May 26, 2009
How do i check ignition coil on makita dcs34
Remove the plug leave it on the wire check for spark plug must be grounded.
Oct 05, 2014 | Makita 14" Chain Saw Dcs34
Makita DCS34 chainsaw After a period of use ( this varies from 15 mins to 90 mins) the saw will tick over but will not rev ( just as if it is running out of fuel) also the priming bubble sticks in when...
This could well be an issue with the fuel tank breather, when the problem occurs try quikly losening the fuel cap, if it picks up again it needs the take breather replacing
Apr 03, 2011 | Makita DCS34 Commercial Grade 14Inch 33cc...
Chain keeps coming off my new 16" Makita chainsaw. Any suggestions?
Make sure that your chain is properly tightened and that the bar does not have any dents or dings in guide groove.I like to have my chains tightened to where you can pull them up at the mid-point of the bar about enough to fit the thickness of a nickle in between it and the bar.Do this when saw and chain are at operating temperature.If nothing else helps try a new chain if you have reached the end of tensioning adjustments. Thank you.
Mar 25, 2011 | Makita 33cc Chain Saw w/16" Bar DCS34-16A
What should the compression be for the makita dcs34?
As far as i am aware it sould be between 60 - 80 PSI, 40 - 60 psi indicates ware any lower than 40 no hope
Sep 07, 2010 | Makita DCS34 Commercial Grade 14Inch 33cc...
How do you set up a carb on makita chain saw
You provide no manual, I chose a "DCS34" a link follows: http://www.makita.ca/data/upload/tools/DCS34%20F-E.pdf
It lists no starting point for the "H" and "L" needle valves, I recommend 1.5 CCW from lightly seated. then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter and spark arrestor; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. If the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 02, 2010 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
This saw is less than 12months old,had started and run well now will not start.has a good spark on the plug, engine seems to flood with fuel mix,will not fire at all.Regards Peter
This is a reoccurring theme in most chain saws at on time or another.
I would get a new plug to start with even though it appears to have a good spark. (always start with the easiest first)
Next I would discard fuel in tank and mix a new batch, just in case.
I would also go back over start instructions on manual just to make sure that I wasn't missing a step or had unintentionally modified the procedure. ( I am including a link to download a manual if you don't still have one )
The very last thing that I would try is adjusting is the carb. If you do remember to adjust in small regulated increments. I have a saw that I have marked with a scratch because about every 15 hrs. the set screw has vibrated off its setting.
CLICK BELOW FOR MANUAL
http://www.makita.com/en-us/Assets/images/Products/DCS34/owners_manuals/995700534.pdf
Hope this helps you,
RSMITH972278
P.S. CONTACT ME FOR ANYTHING ELSE
P.P.S. OLEASE RATE ME !
Oct 17, 2009 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
