Question about Garden
Sears Craftsman Eager-1 edger. Model 143.963507. engine won't start. starts with starter fluid but dies out immediately.
  • 7,482 Answers
Hi Carl
Sounds like you have dirt/debris in your caburetor jets, fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 11, 2013
Craftsman 3.0 hp Eager 1 edger won't start?
Replace the primer. they go bad.
Oct 28, 2014 | Garden
I mixed up one spring and the mower idles low on craftsman eager-1 5.0 22 inch cut
I think that model may use the Tecumseh engine and carburetor application. Here is a diagram of what your machine (carb/choke and governor) should look like.
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
May 14, 2011 | Craftsman Garden
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Apr 07, 2011 | Craftsman Convertible 25cc. Gas Line...
Engine starts and dies immediately what could be wrong?
The carburator may be dirty or the fuel filter might be clogged. I would take it off and clean it with some carb cleaner and see if that fixes your problem. It might be benificial to run fuel stabilizer after you clean it.
Apr 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Looking for a manual on a Craftsman Eager-1 lawn mower. Model #131.90300. Sears has discontinued the manual
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Aug 11, 2009 | Craftsman Garden
Tecumseh Sears Eager-1 6HP mower will not start.
I have an old craftsman Eager 1 self propelled 5.0 mower. I have been looking for a manual. The model # looks to be 131.4402 its hard to read. So far I have come up with nothing.
Jun 29, 2009 | Craftsman Garden
I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Jun 13, 2009 | Craftsman Gas Mini - Tiller/Edger
I need to replace the starter rope on my Sears Craftsman edger. I cannot determine how to take apart the starter housing assembly. Model is a Sears Craftsman Edger Model 536.797470 Thank-you
it should be a shroud its all in 1 unit it should have 3 bolts holding it to the engine block un bolt the shroud & e-mail me or call me i will help you get a string in so you can use my name is wade 831-578-4034 if i may help ya
Jun 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
