Question about Brother MFC 420CN All-In-One InkJet Printer
I have a Brothers MFC-9700 3 in 1 Multi-function machine. My old computer everything worked fine but since I changed my computer to a HP Compaq my printer and fax works fine but my computer doesn't see the scanner driver. I tried a bunch of things that people on the internet suggested and none of them worked so I went through Brothers tech and they went through everything that was suggested to me from the people on the computer. Bottom line they couldn't figure it out and gave up. I don't have the software disk from brothers anymore and I don't have warrantee on the HP I bought because it's a used hard drive that was cleaned. Does anyone have any suggestions?
  • Tom Landucci
    Tom Landucci Oct 11, 2013
    I went to site and don't see anything about PS or PCL, what do they stand for?
    New Friend:
  • 38 Answers
Go to brother's website and down load a current driver. try both PS and PCL
Posted on Oct 10, 2013
  • david hooton Oct 11, 2013
    PS is post script driver, PCL is a driver w/ another printer language
    Add a CommentPCL is better at graphics
snakehead
  • 1074 Answers
SOURCE: Brother MFC 420 CN
the brother printer is not a good brand i also have a brother mfc 3220cn and it gives the same problem, what you have to is unplug the machine and let it stand for about 2 days take out the cartridges and clean the printing with air replace back them and plug in.that should remedy your problem.i urge on you never to buy brother printers.if you buy them get a bottle of phensic along with it.good luck my brother.
Posted on Apr 04, 2007
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
SOURCE: Change Language on Brother MFC-215C
PLEASE, can anyone be sure of the eeprom code for GB before I start the procedure, I tried to contact the hotline but I'm not sure of their phone number either.
Thanks for ur help
Posted on Jun 02, 2008
  • 68 Answers
SOURCE: black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
Posted on May 20, 2009
I have an older machine: model MFC 9700. It has stopped receiving faxes and is showing an error message 71. Says to unplug and call Brother. Is this worth repairing? or smarter to invest in new...
Thats up to you. request a repair cost and compair it to the cost for a new one. Your choice mfc 9700 is a good unit. Upgrade to a MFC 4100n its one of the best brothers makes. Hope this helps.
Aug 12, 2010 | Brother Office Equipment & Supplies
I have a compaq presario s3040se desktop the monitor quit
Try turning on the monitor before the Compaq system box, if Win is doing what it should, it will 'find' a 'new device' and reinstall the drivers for it. It may not look right but you can change the resolution after it boots up.
Apr 22, 2010 | HP Compaq Presario S3040SE (DF222AR#ABA)...
Have a brother MFC 7420 multi function Machine. Keep getting signal on screen stating ''Back Door Open'' it is not have cleaned, everything suggested still same. can you help ?
The back door sensor is damaged. You could could try and close and re-close the door over and over until it registers, replace or bypass the sensor, or buy a new printer. Brothers printers are pretty cheap, depending on what your time is worth per/hour, I'd would just replace it rather than waste a lot of time.
Nov 08, 2009 | Brother Multi-Function Center MFC-240C...
Brothers MFC490CW won't print
try and shut down the printer by holding down the power button for a few seconds, then turn it back on. You can also try rebooting the router. You have to do that sometimes because it has the automatic sleep mode.
Aug 25, 2009 | Brother MFC 490cw Color Inkjet...
My MFC 9700 makes a terrible squeeking noise when it prints
To get the service manual for your MFC-9700 (see page 7), go here:
https://www.manualslib.com/manual/456614/Brother-Mfc9700.html#manual
WD-40 works the best, as most parts would not be damaged by it. Try to figure out by looking at it when it is printing what parts are rotating (this may or may not require some disassembly). If you decide to spray something that rotates (like the hubs of the little rubber wheels that move the paper), be careful to use it sparingly and don't spray it all over everything. A spray of 1/100 of a second or less will usually do the job.
Good luck.
Jan 18, 2018 | Brother MFC 9700 All-In-One Laser Printer
Linux Easy Instalation
My mother has one of these. I have tried to get the Brothers to work but I wonder if they have a windows chip in them or something because they don't work too well. I have solved countless linux problems with google. Tell your boyfriend to type in "linux printers" and the name of the linux your using to see if anyone donated a fix to get this printer working. If he still can't figure it out, I'll walk him through it.
Sep 14, 2008 | Brother Multi-Function Center MFC-240C...
MFC 7420 MULTI FUNCTION
i had the same experience, everytime it issue, the best way is restart your pc and printer.
then should be working fine.
Aug 13, 2008 | Brother MFC-7420 Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
