Question about Amcor CF14000 14000 Btu Portable Air Conditioner AC CF14000E-SILVER-RB
Water leaking unit
Water not misting out of tube but leaking from bottom of unit
Side by side whirlpool refrigerator leaking water puddle in front on floor no loose connections and no signs of water from any part of refrigerator
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several areas where you may have a leak.
Let's check it out:
You are going to have to pull the unit out so you can inspect what is going on.
Turn the leveling screws counter clock wise to raise them. Pull the unit out so you may get behind it.
25576703-vzgcvxho43azc0x10cxafhpi-5-0.jpg 1.) Observe the plastic tubing going to the water dispenser.
The plastic tubing after time get dry rot. Have someone push the water dispenser and observe the tubing for leaks. But before this put a paper towel under the bottom hinge of the freezer door.
So, if you observe water coming from the tubing that is your problem.
Or if the paper towel in the front is wet, then you have a major problem. There is a leak in the door tubing which is only repairable by replacing the door, which is several hundred dollars plus service - $600.00. You can disconnect the contacts on the larger tubing valve and not use the water dispenser.
Ok, no leaks. Then you have a drain pain leak. Un-plug the unit. Remove the lower bottom cover in the back. Just several screws. Inspect the drain pan. Is there a water line from the pan to the front of your unit.? Repair the drain pan with duct tape and a silicone adhesive.
Inspect the bottom of your freezer. If there is ice then you have a different problem.
Keep me informed. Glen Burnie, MD., Email goodwinpeg@aol.com, Phone: 414-306-1362.
Mar 15, 2015 | Whirlpool Refrigerators
Rinsed my humidifier with water and wiped the base down, refilled it and now it seems to be making the mist in the base butbisnt making it's way out of the mouth of the dolphin
The tubing to the mouth of the dolphin or the misting nozzle is clogged with mineral buildup and scale.
To clean this, do the following.
Empty the water in the tank and replace it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the unit to sit for 30 minutes, then turn it ON. If mist does not appear within 10 minutes from the mouth of the dolphin. Turn the unit OFF and allow it to soak over night. In the morning, turn the unit ON and allow it to run. Once the mist appears where it should, run the unit until the tank is half empty. Then empty the tank of the remaining solution and refill with Bottled Distilled Water and run the unit until it is empty. This will flush all the remaining solution from the tank, tubing & nozzle.
In the future I would recommend using Bottled Distilled Water on a regular basis, rather than tap water. Doing so, will eliminate the problem of scaling.
Hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | NewAir AU-200E Humidifier
I have a roper side by side, it is leaking from the front left side, and the ice maker is making a misting sound every few seconds like its trying to fill up again but it only sprays water for a second...
First of all, the ice maker is cycling, and does call for water for about every 20 mins or so. Apparently you have a water leak between the water valve and the full tube behind the unit. Turn off ice maker by lifting the level (medal arm) up until is stops. You will need to roll out the whole unit from the wall and locate the plastic tube that runs the back of the freezer side on the back. You may find you tube has either cracked or came apart. You may have to replace the tube. Your local appliance store or home improvement center should have a 1/4 plastic tube in stock, you could need up to 7 feet, remember, all piece to each side of the connection. Some use inserts and other just use John-Guest fittings are pressure locks (push in to release).
Good Luck, you should have Ice soon....
Jul 15, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Bionaire BCM645 Cool Mist Humidifier leaking water
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Jan 05, 2008 | Humidifiers
Amcor CF14000 14000 Btu Portable Air Conditioner AC CF14000E-SILVER-RB Logo
21 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
