Question about Konica Office Equipment & Supplies
Konica bizhub C451 error code c 5104 - Konica Office Equipment & Supplies
    Habit-Forming:
    New Friend:
  • 106 Answers
Transfer belt motor's failure to turn.
1 Check the M1 connector for proper connection and correct as necessary. 2 Check M1 for proper drive coupling and correct as necessary. 3 Check the PRCB connector for proper connection and correct as necessary. 4 M1 operation check PRCB CN13PRCB-3 (REM) PRCB CN13PRCB-6 (LOCK) K-11. 5 Change M1. 6 Change PRCB
Posted on Dec 31, 2014
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
P 21 ERROR SOLV THIS PROBLEMS
replace the black image unit and run registration procedure
Feb 23, 2015 | Konica Minolta Bizhub C451...
Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
Hi
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Office Equipment & Supplies
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Bizhub c451 error code c2259?
Black developer motor failure to turn. You mite try pulling out the Black image unit and shake it to spread the toner and developer along the whole unit. The image unit mite have been stored standing up image units should always be laid flat. All the developer may be sitting at one end of the image unit an so the motor is having a difficult time turning.
Nov 27, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Bizhub C451 error C-3924
c7ff0589-2c1c-428b-8214-5be985c427d0.jpgkonica minolta c451 printing problem
Jul 16, 2012 | Konica Minolta Bizhub C451...
ERROR C- C172
Hi:
I Form Afghanistan I have a Konica Minolta bizhub C451
Prablem is cod C-C172
Plise help me tanks for you.
Merikh Printing Co.
mpoagency@yahoo.com
Dec 29, 2009 | Konica Minolta bizhub C250 All-In-One...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Error code when copying... C6103 on Bizhub C451
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
606 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
