HP 2310ei blank screen
Hi, I have the above monitor which I brought off eBay and picked up from the blokes office. When I plug it in the power light comes on and if I touch the menu button they light up but the screen is totally blank. Does this sound like a back light problem or a more serious screen problem ?
El Duderino
  • 47 Answers
SOURCE: Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 26, 2006
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
  • 85 Answers
SOURCE: HP mx705 17 in.CRT --Blank monitor
I assume the monitor is still plugged into the back of the system?
If so, do you get any beeps which can denote error codes for the system?  Put your ear to the monitor, any strange whinning noise?
Posted on Oct 23, 2007
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
SOURCE: Benq FP71G monitor screen displays momentarity on
check your power supply and power cable and check your monitor cable if its not damaged..or try your monitor to another computer..
Posted on Jan 19, 2010
My 1 year old computer has a black screen but u can hear the computer running help....
Are you getting any beeps while your computer starts up or when it has already started? If yes, then refer to the following HP Support page to get details about different types of beeps and the respective issue they indicate:
http://h10010.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02222922#N315
If you are not getting any beeps, you can start troubleshooting the issue by first checking the connectivity and performance of your monitor. To do this, refer to the steps below:
1)Make sure that your monitor has power and the power light on it turns On when power is supplied to the monitor. If the light stays Off, turn Off the power supply- unplug and plug the power cord- reseat the power adaptor connection on your monitor's end- turn On the power supply. If the monitor's light glows, see if the computer still shows the blank screen. If yes, follow the steps ahead.
2)If your monitor is of flat panel LCD type, unplug its power cord and wait for around 30 seconds so that the electronics in your monitor are reset. Now reconnect the cord and turn On the monitor.
3)If you are still facing the blank screen issue, disconnect all the connected devices to your computer except mouse, keyboard, and monitor. Also remove memory cards from card reader slots (if any) and thumb drives connected to your computer (if any).
4)If the above steps do not resolve your issue, you can try (if possible) to connect your monitor to another video cable (if it is detachable) for testing purpose.
If the issue still persists, you can refer to the HP Support links below to troubleshoot your issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02217843&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=5296671#N69
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03561545&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=5296671
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03518095&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=5296671
GuruAid.com
Jul 07, 2014 | HP Black Envy TouchSmart 20-d13w...
HPw2338h screen is black and says going to sleep?
They usually go off when the don't detect a signal from the computer, make sure the connection is ok between them.
Jan 28, 2012 | HP Computers & Internet
I bought hp dv2630ea laptop 3 years ago, recently my laptop screen went into blank, no light, no image on the screen. i brought it to the hp service authorized center in hyderabad, they said problem with...
The LCD screen may be faulty. I suggest you borrow a monitor to test your laptop if you do not already own one.
If the laptop appears to boot up and the hard disk LED flashes, then connect an external monitor to the laptops video port. Power up the monitor and then boot up the laptop and the video information will automatically divert to the external monitor.
If this works then you have a working laptop.
Dec 09, 2010 | HP Computers & Internet
My hppavilion f1503 flat panel lcd monitor screen stay blank
The monitor should be plug and play, and you've already figured out that it's not your computer by plugging into a working monitor.
This is most likely the power inverter board in the monitor - this is common in many monitors. If the power light is blinking on-and-off, or just staying on with no image, that's the problem. There is a slight chance that it could be the light itself, but inverters fail more commonly.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 04, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
