Question about Shark Euro-Pro Professional Steam Pocket Mop S3601 with 3 Quick
How to disassemble Shark Mop s3601? I took all
How to disassemble Shark Mop s3601? I took all screws off, but cannot separate covers.
    New Friend:
You need to remove the shark and power button sticklers. There is two screws in each. Once you remove the screws you slide the grey cover and remove 3 more screws holding the chrome piece. Now you can spread the cover open. I just replaced a torn hose.
Posted on Dec 01, 2013
This is the third time--I need the directions
Go to Shark's website to find the manual to download.
Aug 08, 2015 | Shark S3601 PROFESSIONAL STEAM MOP
My steam mop heats but doesn't steam. almost every time I used it, I used distilled water
Try filling the tank with pure white vinegar and plug it in, pump the handle to get the vinegar through the hose and let it sit for a half hour to dissolve any gunk that is built up, CLR works well for this also. Once it has sat, empty the tank and fill with fresh water.
May 04, 2015 | Shark S3601 PROFESSIONAL STEAM MOP
Hoe do you remove the top most cover of oreck air purifier
screws on the bottom need to be removed it separates in 2 pieces
Sep 02, 2014 | Oreck Air Purifiers
Red devil steam mop not steaming
Check that plastic tube is not blocked or disconnected. Always use filtered water in tank.
Oct 25, 2013 | Dirt Devil Pd20000 Easy Steam Mop
Shark steam mop troubleshooting
This is a bad sign. The heating element has either come loose or the thermostat has failed to shut the heater down. Dont use it anymore. You can disassemble it and see what the damage is but the smell leads me to believe that it is damaged to the point that is should be replaced. Check the warranty to see if it is covered.
May 17, 2013 | Shark Euro-Pro Professional Steam Pocket...
How do i take the Shark S3601 apart?
Water is spilling from the hook upconnection to the carpet slider.
Solution: It needs to replace an O ring in the junction.
Question is: How do I remove the junction?
Dec 30, 2012 | Shark S3601 PROFESSIONAL STEAM MOP
Honeywell air purifier, will not turn on, obviously getting power. but pushing the buttons on the control panel does not result in the machine turning on. This is the 17000. Can anyone help?
Does this unit have a 3 volt battery in the control panel like the 17005 model? The battery lasts appx 4-5 years then the unit doesnt seem to work any more once you change it. The unit must be left plugged in while you change the battery otherwise you lose your programing. If your not under warranty, UNPLUG it then pull out the filter, take out the 6 screws, separate the sides, and expose the fan. If the fan does not spin very easilly with no drag, the bearings are gummy; which is why nearly all small motors get replaced. The motor can be easilly disassembled, gummy grease washed off with rubbing alcohol and a cotton swab, and reoiled with synthetic oil. These units are designed to gum up and require replacement at approximately the same time the warranty expires. They would last almost indefinitely if oiled in their little oil ports occasionally (every couple of years). If your bearings are stiff, then a hidden safety device has tripped to avoid a fire, and if you are handy, you can replace the blown fuse if you can locate it on the circuit board, or the blown over temp device. If you have to pay some one to do this, it is cheaper to replace the whole machine in this throw away world.
Nov 25, 2009 | Honeywell 17000 Air Purifier
Ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Nov 03, 2008 | Sharper Image Professional Plus Ionic...
Shark Euro-Pro Professional Steam Pocket Mop S3601 with 3 Quick Logo
893 people viewed this question
Top Shark Air Purifiers Experts
Lawrence Oravetz
David Payne
David Payne
Are you a Shark Air Purifier Expert? Answer questions, earn points and help others
