Question about Garden
Snapper sr1433 mower
I need front wheels for my SR1433, can not seem to find the ones that or own them. 4x11x4
  • 32 Answers
Here is probably what you are looking for. http://www.amazon.com/11x400x4-2ply-Turf-Saver-Carlisle/dp/B005C9Q22E/ref=sr_1_8?s=lawn-garden&ie=UTF8&qid=1382349922&sr=1-8&keywords=4x11x4+tire
Posted on Oct 21, 2013
3 Suggested Answers
  • 420 Answers
SOURCE: Is the rubber on the drive wheel on the snapper
Yes, it may have gotten excessive oil on it and swelled the rubber. Replace the drive wheel.
Posted on Jun 18, 2010
  • 6468 Answers
SOURCE: how to add oil to snapper lawn mower
if there is no dip stick then look about a inch above the base of the engine for a plastic screw about 1/2'' in dia
Posted on May 29, 2012
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
My snapper mower LT12D41 rod to connect two front tires came off
it's called the Tie Rod, and there are usually bolts at each end that holds a swivel to the sterring knuckle.
Jul 15, 2014 | Garden
Snapper mower
Remove the wheel from the axle. Then using a 1/2" drive pin or a metal rod at a slight angle thru bearing of one side, drive out the bearing of the other side. Repeat for other side as there are 2 bearings per wheel.
Jul 14, 2014 | Garden
Snapper sr1433
check harbor freight for something close 4.10/3.50 x 4 tire with wheel...
keep in mind that the bearings in the wheels can be changed and you might need to use washers as spacers. check a local dealer as well
Oct 10, 2013 | Garden
I have an older Snapper lawn mower that just stopped moving while I was mowing grass. I have put a new drive plate on it (the one that has the rubber around), but that didn't help it. When I stand the...
your trans axel has striped out in side you will need to get that in to the shop let me know if this helps you or if you need to find a shop
Oct 04, 2009 | Garden
Snapper comet rubber drive
Get a new drive wheel.
Put mower in neutral.
Stand mower on rear supports.
Remove the four bolts holding the old wheel.
install new wheel.
Jun 15, 2009 | Garden
Need to know how to adjust the rubber drive wheel on a rear engine snapper. Any help will be great. Thank you
Usually just replacing the drive wheel will fix the problem. There are two allen head set screws on the disc mounted on the engine shaft visable through the hole in the rear of the mower. However, don't expect when you loosen them that the disc will move up or down freely. I've only ever move one by taking the engine off. I'd try replacing the rubber drive wheel first.
Jun 14, 2009 | Omega Rear Drive Wheel Snapper Mowers
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
