Question about Garden
Snapper sr1433
Need front wheels for my sr1433 lawn mower. what size will work, I cannot seem to find the size that I have!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check harbor freight for something close 4.10/3.50 x 4 tire with wheel...
keep in mind that the bearings in the wheels can be changed and you might need to use washers as spacers. check a local dealer as well
Posted on Oct 22, 2013
  • 4 Answers
SOURCE: The front wheels on my lawn mower have locked
I had this same issue. In my case, the sheild that keeps the dirt out of the gears in the wheel has gotten broke and the gears filled with junk and jammed the wheels. I just have to take the wheels off and blow the junk off the gears.
Posted on Jun 07, 2009
mhamlin63
  • 138 Answers
SOURCE: Self propelled lawn mower inside of drive wheel gears stripped.
Check the drive shaft bearing closest to that wheel.
Posted on Jun 29, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
Change rear wheels on self propelled lawn mower
unbolt wheel or re move hub cap or a nut cover pull of the retaining clip remove wheel reinstall in revers with new wheel retainig clip if bolt just tighten up
Sep 03, 2014 | Omega Rear Drive Wheel Snapper Mowers
Snapper mower
Remove the wheel from the axle. Then using a 1/2" drive pin or a metal rod at a slight angle thru bearing of one side, drive out the bearing of the other side. Repeat for other side as there are 2 bearings per wheel.
Jul 14, 2014 | Garden
Snapper sr1433 mower
Here is probably what you are looking for. http://www.amazon.com/11x400x4-2ply-Turf-Saver-Carlisle/dp/B005C9Q22E/ref=sr_1_8?s=lawn-garden&ie=UTF8&qid=1382349922&sr=1-8&keywords=4x11x4+tire
Oct 10, 2013 | Garden
I have a Snapper RT8 tiller that needs a new belt. What type and size of belt does it take and is there a schematic for routing the belt.
you need the model number on the tiller should be a tag on it somewhere and sometimes the serial number as well to get the right size
Oct 16, 2011 | Omega Rear Drive Wheel Snapper Mowers
Old snapper riding lawn mower with the handlebars
Usually the drive disc . Look under mower at rear, you will see a wheel with rubber ring on outside diameter. I think, it is four small bolts holding it on. Take off and replace, will usually solve problem.
Mar 23, 2010 | Garden
I have an older Snapper lawn mower that just stopped moving while I was mowing grass. I have put a new drive plate on it (the one that has the rubber around), but that didn't help it. When I stand the...
your trans axel has striped out in side you will need to get that in to the shop let me know if this helps you or if you need to find a shop
Oct 04, 2009 | Garden
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
