Question about VeriFone Inc MX 880 Payment Terminal - M094-507-01-R
Mx880 able to download .tgz file, "Download Successful", yet when i hit GO it boots up to only System Information.
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
I downloaded a Linux program from the Internet to my download directory. How can I install it?
It depends on situation.
What is your operating system?
Windows:
No easy way exists to run Linux program in windows. Use VirtualBox or VMware virtual environment, download Linux OS, install virtual Linux machine and then install your downloaded program in Linux.
VirtualBox free download (virtual environment):
Welcome to VirtualBox org
Ubuntu Linux OS free download (virtual machine):
http://www.ubuntu.com/download/desktop
Your final installation set look:
Your downloaded program
Linux operating system - installed as virtual machine
Virtual environment
Windows OS
These components are installed on computer
Linux:
There exists more program packages types :
RPM package installation (Centos, RedHat, OpenSuse...)
rpm -ivh program_name.rpm
Debian package installation (Ubuntu, Debian...)
sudo dpkg -i program_name.deb
or
sudo apt get install program_name
General compressed file / installator
File extesion examples:
package_name.tgz
package_name.tar.gz:
Unpacking
tar -xvzf program_name.tgz
Installation of executable file :
./install.sh
(or another file from the package)
Jan 19, 2016 | Computers & Internet
How to restore corrupted lotus notes? Corrupted file format NSF.Kak me recover and I download Lotus Notes Recovery tool?
Automatically converts repaired images into a clean file of AI format after the registration; Goes with detailed explanation of all steps, needed for successful restoration http://www.techrepublic.com/forums/questions/how-me-recover-and-i-download-lotus-notes-recovery-tool/
Apr 10, 2015 | Microsoft Office Professional 2007 Full...
I have a problem with my literati ereader its functioning well until I upgraded it last week now it wont recognize my sd card..I tried others it just wont recognize it. then I tried putting some of my...
Solution: Use the Literati USB connection and the following steps
1. Plug the eReader into a charger
2. Download v2.0 of the Literati or Lookbook firmware from - http://download.kobobooks.com/firmwares/merchsource/2-0/KoboRoot.tgz , and save the file somewhere you will remember
  • NOTE: Some browsers will download the file and rename it to KoboRoot.tar. The upgrade will not work with the .tar extension. If this happened with your download, please rename the downloaded file to KoboRoot.tgz
3. Keeping the charger connected, connect the Literati or Lookbook to your computer through the provided USB cable
4. The eReader will appear on your computer as a mass storage device
ON A MAC:
1. Open mass storage device in Finder
2 . Click GO from the top menu
3. Click Go to folder
4. Type in .kobo (include the period).
5. .kobo folder will open
6. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
7. Once the file has transferred, safely eject the eReader
8. Turn off the eReader
9. Turn on the eReader
10. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
11. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
ON A PC:
1. Open mass storage device in Windows Explorer
2. Ensure hidden folders are visible (different for different Windows versions)
XP: Go to My Computer > Tools menu > Folder Options > View Tab > Advanced Settings > Hidden Files and Folders > Show hidden files and folders. Press OK all the way out.
Vista and Windows 7: Start > Control Panel > Folder Options > View Tab > Click Show Hidden files and folders > OK
3. Open .kobo folder in the mass storage window
4. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
5. Once file has transferred, safely eject the eReader
6. Turn the eReader off
7. Turn the eReader on
8. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
9. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
Sep 04, 2011 | Sharper Image Literati Reader 16375680042...
Unmountable boot volume
If your notebook came with a Windows installation disk, you can fix the issue this way:
1. Insert the installation disk into your CD/DVD drive, and boot up your computer.
2. At the Welcome screen, hit the R key on your keyboard. This will launch Recovery mode.
You should now see a DOS prompt on your screen.
3. Type chkdsk /p and hit Enter. This will launch a utility that scans for hard drive errors.
The process may take some time, so be patient and allow it to do its job.
4. After the chkdsk is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When prompted to choose "Yes" or "No," type Y for "Yes."
5. Type exit and press the Enter key to reboot your computer.
Assuming chkdsk was successful in fixing the disk errors, you should now be able to boot back into Windows.
If you do not have a Windows installation disk, but have access to another computer with a CD/DVD writer, you can download Hiren's Boot CD to help fix your corrupted boot drive.
1) Download the Hiren's disk image, and follow these instructions for burning the boot CD.
2) To ensure your system boots from the CD you've created, follow these instructions on how to set your BIOS to boot from CDROM.
3) Alternately, you can download a free utility that will create a bootable USB flash drive containing all of Hiren's tools. The above link also provides step by step instruction on creating a Hiren's USB drive, as well as how to set your BIOS to boot from it.
4) Boot the problematic pc from either your Hiren's CD or Hiren's USB drive.
5) Once you've successfully booted your system using Hirens, you will see a menu with a variety
of tools and utilities. Navigate to the hard disk tools menu, and run HDD Regenerator.
You'll need even more patience this time -- as HDD Regenerator is a bit more comprehensive in its error scanning than chkdsk. On the bright side, HDD Regenerator has a reputation for repairing disk errors that chkdsk was unable to.
Good luck, and I hope this helps!
Jan 08, 2011 | Dell Inspiron 6400 Notebook
Dell dimension wont boot after power outage and stops half way through the boot page
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
Mar 12, 2010 | Dell Dimension E521 PC Desktop
First freeze, then boot slow, then boot "PBR 2 ...done, then disk read error Ctrl Alt Del to contine..., now no screen at boot up....fried???
Steps for solution
Mar 11, 2010 | Dell Inspiron 6000 Notebook
Funny ust scandal
Try booting to safemode. and delete it from there.
To boot to safemode, restart your computer and tap F8 once your computer starts booting up again. on windows advanced options menu select safe mode then hit enter. hit enter again if it asks you for the operating system.
If you still can't delete the file try to download MoveonBoot here.
Just install the program. once it's installed right click on the file you wish to delete and select the option to delete on next boot.
Oct 08, 2008 | Dell Inspiron 1300 Notebook
Intel PRO/Wireless 2200BG Network adapter not recognized
Hi
Check Intel PRO/Wireless 2200BG Downloads - http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637
Select Linux from and click on go
You can download Intel PRO/Wireless 2200BG version 1.2.0 or 1.1.0
Installing/updating Intel PRO/Wireless version 1.2.0 driver for Linux
- To extract the archive file, type from a console: tar xzvf ipw2200_linux_1_2_0.tgz
- To install the driver the following is needed:
1. Linux with a 2.6.8+ kernel. See README.ipw2200 for information on
specific options required to be enabled in the kernel.
2. Wireless Extensions (v16) and Tools (v27-pre23) if not included in
your distribution
3. The driver (ipw2200-1.2.0.tgz)
4. The binary firmware image (ipw2200-fw-3.0.tgz)
5. For instructions on how to build and use the driver, please see the INSTALL document in the ./intel_ipw2200_120/ directory.
More info http://ipw2200.sourceforge.net
Regards
Mike
Oct 01, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
VeriFone Inc MX 880 Payment Terminal - M094-507-01-R Logo
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
