Question about Kitchen Appliances - Others
Sidewalls of bread dent in - Kitchen Appliances - Others
I am making a plumbing repair to copper pipe. There is a small trickle of water that I cannot stop flowing. What is a good way to block the water to make a good joint?
Jamb a piece of white bread(wadded into a tight ball)into the pipe. Work fast. Bread will stop flow for a bit, but will breakdown quickly under pressure and dissolve with no blockage.
May 04, 2017 | Plumbing
Are tires worn out?
The tire rubber will crack with age and exposure to the elements. If you look in between the tread pattern you may well find some cracking there as well.
Once cracking in the sidewalls and/or in the tread section appears it is most definitely time to discard those tires.
Dec 05, 2015 | 2000 Chrysler 300M
How do i remove dent from a car without ruining the painted surface and many more?
Depends on how deep the dent is, is it a sharp crease, has the paint cracked in or near the dent? There are kits available that can pop out a simple dent, but not a more severe dent. You can Google paintless dent removal to see the kits and where to get one.
Aug 21, 2014 | Toyota Corolla Cars & Trucks
Need pan for West Bend 41073
It's a little bit dented but will work fine. I would sell for 15.00 and free shipping in the U.S by United parcel service.
Nov 11, 2011 | West Bend 41053 Bread & Dough Maker
My bread falls there is a large dent in middle
Loaf collapses:
Using the last recipe you used decrease the liquid content by 1 tablespoon. If you still aren
Sep 01, 2011 | Black & Decker Bread Machine
I have a Sunbeam Breadmaker Model 5891 and I need a new bread pan; it's dented and the seal around the paddle is worn out. Where you one purchase them?
goto the amazon website the bread pan is there and also bread kneeder thats £6.05 EACH THE LAST TIME I LOOKED TWO WEEKS AGO
Jan 20, 2011 | Sunbeam 5891 Bread Maker
My KitchenAid mixer clicks when I mix bread dough and any other thick batters. How do i fix it?
Make sure your dough hook isn't bent.... or your bowl doesn't have a dent in it.... and make sure the bowl is properly seated and secure.
Aug 29, 2010 | KitchenAid K45SS Classic Stand Mixer
I got a used bread machine Model# K675. I have
Make sure you grease the pan a bit before putting ingredients in. Or just use the dough setting and bake the loaf in the oven when the dough is done.
Jan 22, 2010 | Regal Ware Kitchen Appliances - Others
Replacing belt on bread machine
Where did you get the replacement belt ? My brother is looking for a belt for a similar model K6761 which uses the same belt (I think). It is about 24" around and 1/4" wide. It has (3) grooves inside and the backside has many notches. The motor has grooves, it would go on there. Where did you get the replacement belt ? thanks regus_patoff_2000@yahoo.com
Feb 02, 2007 | Regal Ware K6725 Kitchen Pro Bread Maker
Kitchen Appliances - Others Logo
15 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
