Question about Sharp AL 800 Copier
Blinking H4 onAL-800 - Sharp AL 800 Copier
Sharp m165 error h4-00 give solution
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
May 12, 2014 | Sharp AR-BC260 Color Copier
My shure ur4d receiver is blinking not working
Probably a bad power supply. Call Shure Service at 800-516-2525 to have it repaired.
Feb 28, 2013 | Shure UR4D (2-CHAN) DIVERSITY RECEIVER...
Removing the error H4-00 code
In Toshiba Printer the error codes generally occur due to instability of drivers in system and also due to system related issues either it is supporting or not .So for proper assistance on this issue just get connected at Toshiba Printer Support Number 1-800-243-0019 and get in touch with expert technicians and get your issues resolved. Visit: Toshiba Printer Support Phone Number 800 243 0019 for Help
Aug 27, 2012 | Toshiba e-studio 203sd
Sharp AL-800 is blinking H and 4 what could be the problem?
the error code H4, means that an abnormal temperature was detected in the fusing section (the hot roller was not working properly during the initialisation of the printer), to solve the problem;
  1. unplug the printer from the power source
  2. wait for 10 mn
  3. plug the printer again to the power source
  4. switch on the printer
if the error H4 still displayed, you need change the fixing unit, that must be doing by a qualified technician,
Dec 14, 2010 | Sharp AL 800 Copier
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
Jul 07, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
H4-00
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and rarely the temp sensor.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Feb 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Jan 25, 2009 | Sharp AR-M350N Copier
Sharp AL 800 won't copy. Blinking letter and number H 2
H2-0 Fusing unit temperature error
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
Also check thermal fuse, if defective replace.
Jan 25, 2009 | Sharp AL 800 Copier
Sharp al1217 h4 blinking
H4 is a fuser heater code. This is most often a heat lamp.
Nov 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL 800 Copier Logo
15 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
