Question about Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does not mute when headphones are plugged in. How do I change this?
    New Friend:
  • 19 Answers
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Posted on Oct 12, 2013
SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
Posted on Jan 05, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
Sony Bravia tv, can't get sound out of wireless headphones with base station plugged in
Check the Volume on the TV, the audio jack is tied to the TV volume control.
Jan 09, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Won't turn on
Check up your plug point,whether power is available at this point .Or try the TV with someother plug point .Get authorized Sony service center's help.
Apr 13, 2014 | Sony Bravia Kdl-55ex720 55" 3d 1080p Led...
No sound
Check its speaker first. If found OK, check and replace damaged component/s at its audio output card, or, replace it as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 03, 2014 | Sony Bravia S-series Kdl-40s2010 40-inch...
I get no sound from the tv when cable is connect. How do I get sound
ensure your tv is not in Mute mode. ensure your tv does not have Headphones or cable in headphone socket, this will mute the speakers.
ensure the volume is turned up. test your cable on alternate tv if posible to test cable is correct. if still not working, contact Sony customer support.
I hope this was useful
Oct 20, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia 40" LCD, not getting any audio out of the headphone jack. Have tried different types of headphones. When I plug my headphones in to the side headphone jack I'm not getting any sound. The tv...
go to your remote contol ( menu )
then you go to the option set up.
then you go to headphones and you can set the volume louder.
You will see that it works fine.
Greetings from Holland Gesinus
Jan 14, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
My Sony BRAVIA KDL-V32XBR2 32 has lost its sound. I have checked that the speaker setting is on, the mute is off. Is there anything elsei I can check?
please try differect sources e.g. dvd, cable TV box, aerial. Also check that your connectors are properly plugged in. If none of those work, bring your tv to the nearest service center.
cheers!
Jul 11, 2009 | Sony BRAVIA KDL-V32XBR2 32 in. HDTV LCD
Where do I find the place to connect headphones on the bravia xbr
Try this: face the television; Left hand side on the edge; Look for the green input port (top hole); plug in headphone jack; should work
Dec 22, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia KDL-46Z4100 46 in. LCD HDTV Logo
239 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
