Question about Cub Cadet Garden
Loss of power, smoking, and the oil is clean but has bubbles in it
  • 28 Answers
This could be bad, but this is a good sign that the rings are bad or a scored cylinder. might have to be rebuilt or think about junking
Posted on Oct 11, 2013
Power loss and smoking
Toyota Hilux engine power loss Questions & Answers - Fixya
www.fixya.com > ... > Tags > engine power loss > Cars & Trucks > Toyota
Toyota Hilux cars & trucks engine power loss questions and answers. Ask your Toyota engine power loss related question. ... Question about 2006 Hilux 3.0.
Sep 27, 2015 | 2006 Toyota Hilux 3.0
Ford transit 110 T280 I've back smoke on excellaration and loss of power on inclines; could it be the EGR valve at fault ; also have management warning light on.?
Needs piston rings. You have lost compression so you are losing power. The oil is getting pasty the worn rings and entering the combustion chamber which would explain the black smoke and loss of power.
May 18, 2014 | 2009 Ford Transit Connect
My engine light comes on, I have loss of power and lots of white smoke, it is not the diesel supply as I have cleaned the tank, replaced both the inline water trap and the diesel filter. My turbo is f
is it smoke or steam .if it is steam it could be head gasket problem if it is smoke it could be a faulty turbo or if smoke has a blue tinge to it its burning oil or it could be overfilled oil sump
Mar 13, 2014 | 1999 ISUZU TROOPER 229501 Flywheel -...
White smoke coming out of exhaust, engine not overheating loss of power does not appear to be losing water
White smoke from the exhaust is a sign of coolant entering the combustion chamber. You say no coolant loss, or overheating. Is there a white foamy substance under the oil cap, & air bubbles escaping from the radiator? If so you have a leak and more than likely it is a blown head gasket. I would have a cooling system pressure test run. Do not continue to drive this Ford in this condition. Something is not right and you need to find out what is going on.
Apr 09, 2010 | 2000 Ford Focus
White smoke oily back window 1993explorer no oill loss on stick
head gasket gone ,no oil loss?? the water is going in the oil
Dec 24, 2009 | 1993 Ford Explorer Limited
Head gasket
Typical symptoms of a blown headgasket may include: -bubbles of air coming up into your radiator (remove cap before starting) -leaking radiator -milkshake colored oil -overheating -rough running -coolant or oil running from head -spark plug(s) that have a green tint (if green coolant). -white colored or sweet smelling exhaust, white smoke of your tail pipe, or loosing coolant through your overflow
Dec 22, 2009 | 1989 Chevrolet S-10 Blazer
Jetta4 1.9tdi 200 model
the bubbles are nothing unless you get too many ,you will always see a few but not to excess if you do then renew the rubber hoses under the bonnet and ontop of the tank.But without having it front me the cause of the smoke and the power loss would be the ERG valve ,this is the valve that connects the inlet manifoltd to the exhaust manifold ,try pulling off the rubber vac pipe that runs to the top of this valve and see what happens ,bet the smoke clears and it runs ok .
Dec 14, 2009 | 2002 Volkswagen Jetta TDI
I have a 2002 kawasaki prairie 650. i think i have a blown head gasket on the rear cyclinder. how can i be sure it is a blown head gasket?
Check the seal behind your water impeller there are o rings back there if one of them goes bad you will leak antifreeze into oil, your impeller is run by the oil pump i believe, you should not see oil in the water also your bike will run fine but when hot will foul the plug with water look for white smoke sometimes and the smell of anti freeze on start up
i have a 400 4x4 doing the same thing new piston rings and top end now lossing water but runs great oil looks real thin
took to the dealer to fix this week will let you know how i make out.
Mar 03, 2009 | 1990 kawasaki ZZR 600
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
