Question about Brother MFC-J825DW Wireless All-in-One Inkjet Printer, Copy/Fax/Print/Scan
Printer not detecting ink cartridge - Brother MFC-J825DW Wireless All-in-One Inkjet Printer, Copy/Fax/Print/Scan
While printer is on try to:
1.Open ink cartridge doors
2.Remove ink cartridge carefully (be careful not to spill ink)
3.Wipe inside of printer (take special care about ink level sensor, it's where part of ink cartridge is transparent, to make it possible to measure level)
4.Wipe cartridge outside so measuring sensor will have "a clean view"
5.Insert cartridge firmly
6.Close doors firmly
Posted on Apr 29, 2016
    Sergeant:
  • 317 Answers
Clean contacts, check level. Is it OEM or a refill cartridge???
Posted on Oct 22, 2013
Hp 6515 cartridge shows low after a refill
There is no such mechanism to detect ink levels in your printer., it wont detect if adding more ink in it., it will detect only new cartridge when you replace it., printer shows estimated ink levels as per the print outs. This is hp trick to aviod refill &non hp consumables...
Sep 30, 2014 | HP Photosmart 6515 Wireless Color All In...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
I refilled the ink cartridges on my canon mp250 copier because it stoped printing. The little info box said that the ink was running low now it still won't print . I 've re inserted the ink cartridges...
originally, when u have ink cartridges in Canon product run low u need to buy new ones, because it was designed like that. even u have refilled the old cartridge full, it will detected low ink because the old cartridge already detected for the beginning. this designed to make Canon buyer to buy new ones ink cartridge. but, there some trick to make your old cartridge detected as new one, all u need just to reset the setting for cartridge recognition. try to visit this site:
http://resetcanon.com/reset-canon-mp250-pixma-inkjet-all-in-one-printer/
maybe this site can help your problem, regard riyan.
Mar 09, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
I have replaced all the colours in the last few weeks, the printer is saying that magenta is out but there is still ink in the cartridge, when i shook it the ink spilt out.. I hate this printer its caused...
Hi there !
There should be ink resetter in your your printer. Just reset it and it will detect the ink cartridge.
If not, purchase chip resetter available in the market that enable your printer to reset the chip set and detect your ink cartridge.
Because on required ink cartridge is recommended. If you use other brand of ink cartridge, it will damage your printer and soon enough it will not detect anything at all.
Jan 13, 2011 | Office Equipment & Supplies
The printer wont recognise an ink cartridge, even though it is the correct one!
if ur using generic ink it may not detect it or it may detect wrong cartridge maybe u need to buy canon ink cartridges .
Jul 26, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How to fix problem E16 in my printer canon mp160
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
Sep 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
Brother MFC-J825DW Wireless All-in-One Inkjet Printer, Copy/Fax/Print/Scan Logo
117 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
