Remove Memory guard on Yamaha HTR 5940
How do i remove the memory guard on the yamaha htr 5940?
    Genius:
  • Audio Player... Master
  • 1,054 Answers
Select memory guard and press the sideways cursor to select no. it should turn the lock off.
Posted on Oct 10, 2013
4 Suggested Answers
  • 336 Answers
SOURCE: turns on then off.
It probably needs a set of output transistors, 2 pre-amp transistors and a 5.6v zener diode. Possibly a resistor or two. I've fixed many of these. Definitely a job for a pro.
John W
Posted on Jan 10, 2009
  • 50 Answers
SOURCE: All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Posted on Jul 05, 2009
Nomodo4u
  • 863 Answers
SOURCE: how do I connect my xbox 360 to my yamaha HTR 6230 receiver?
Use HDMI because they combine picture and sound in one convenient cable. You can buy the cheapy ones because they work the same as the pricey ones with no degradation in sound quality or picture.
Posted on Feb 18, 2010
I have the Yamaha HTR-5940 and it has worked fine for years. Today turned on and there is no sound for the TV. Sound works fine for DVD, and radio. I have tried everything except toss it out the window....
did you connect the cables correctly most probably to get sounds out of a tv it should connected to the 3.5mm headphone jack.
you would need a Rca to 3.5mm cable for this
Oct 20, 2017 | Yamaha HTR-5940 Receiver
I was told i might have a fuse blown on my htr-5940,cause the 3 left speakers work for the test but not for actual playing.is that the problem?and where can i find the fuse?
There's no separate fuse for test versus operational speaker function.
Evaluate the source for why the "3 left" speakers (whatever that means) don't work for program material.
Jun 27, 2011 | Yamaha HTR-5940 Receiver
I have a rca no rtd250 impedance 12 ohms subwoofer. how do i connect it to my yamaha htr 5940.do i need a special cabel where do i get it.
The Yamaha can only drive powered subwoofers. Make sure that the RTD250 has it's own amplifier built in, you won't be able to easily run it off the yamaha if it doesn't.( the powered subwoofer will have a mains cord to power if it's correct) If it doesn't have a amp built in, easiest weay is to buy a cheap powered sub.
Is the RTD 250 the sub fromthe RCA home theatre pack?
Jan 14, 2010 | Yamaha HTR-5940 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
Turns on then off.
John W
Jul 22, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 turns off after one second.
HI my Yamaha is working fine exept input selector , I selilng it for parts 45 , amp working fine exept inputs ( one milti channel in works fine) korrado6@hotmail.com
Jun 21, 2008 | Yamaha HTR-5940 Receiver
HTR-5940 6.1 Channels
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Apr 21, 2008 | Yamaha HTR-5940 Receiver
Sound cutting out
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
May 09, 2017 | Yamaha HTR-5850 Receiver
160 people viewed this question
 Grubhead
Grubhead
