Question about HP DeskJet 930c InkJet Printer
Print is not straight
Hi esteemed problem solver I've often had this problem,with other printers too. It seems particularly bad on the 930 though. What happens is that the left margin on the printed page gradually gets bigger while the right margin gradually gets smaller.The result is that letters etc don't look good. Thanks for your help
  • log120 Sep 26, 2007
    Thanks SparkGap. What you wrote was entirely sensible. I would rate your advice as excellent and myself as blooming useless! The trouble is that I inherited the printer without any documentation.I'm sure there must be some way of guiding the paper, as you wrote, but I can't see how to do it. I've tried. I think the problem lies there and not with the worn pinch rollers as the machine looks in good condition to me.
  • log120 Sep 29, 2007
    Thank you for that SparkGap. I had noticed a lever but it wouldn't move. When the manual confirmed that it was indeed the correct one, I tried harder. Eventually I realised that holding the lever and yanking was no good, you have to slide your fingers past the lever and then it glides along smoothly.
    So many thanks.
  • 363 Answers
It sounds like the paper is being pulled into the printer at a crooked angle. Check that the guides in the paper supply tray are adjusted correctly to the paper width and are tight against the stack of paper. Alternatively one of the rubber pinch rollers that pull the paper though is slipping or worn smooth. Regards
Posted on Sep 24, 2007
  • Martin B
    Martin B Sep 29, 2007
    I can definetly help with one of your problems:-
    Get your manual here.
    http://h10025.www1.hp.com/ewfrf/wc/manua...
    Hopefully you'll see the way to guide the paper properly.
I've got vertical lines down my photos
Usually happens when print heads have been damaged usually from inferior inks have print heads replaced if possible, If it is only happening with particular software try another printing program, If problem is present still either repair print heads if possible otherwise replace printer. I hope this helps
Aug 30, 2012 | Epson Stylus Sx400
Server 2008 drivers for HP deskjet 6122
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with many Windows systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch.
Jul 04, 2012 | HP DeskJet 6122 InkJet Printer
I want to print in grayscale
Try a different driver. "Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). All these drivers seem to be the same print quality in my systems.
Feb 03, 2012 | HP DeskJet 6122 InkJet Printer
Hi, I am having problems printing a Word document. When I press Print, it only prints two-thirds of the page. What am I doing wrong please?
Okay, the paperfeed at the top, on the left hand side there is a grey slide, (right in the printer) to hold the paper in place. Use it to keep the paper straight! It seems that if the paper goes in straight, the whole page is printed, if it doesn't it messes up the page.
Worked for other people having trouble with Epson Printers
Sep 15, 2011 | Epson Office Equipment & Supplies
Will not print. says it's out of paper but the tray is full
Sounds like the paper pick-up assebly has gone bad. The lifting mechanism has gone bad for that particular cassette and the only thing I've done is replace the whole assembly. I tried to repair the assebly but it's too time consuming and you still have a used assembly.
Mar 04, 2011 | Canon imageRUNNER 2200
Hi, I have been using a Kodak ESP 5250 for a while but have just tried to print a doc. and have ' Printer not responding '. Checked for connection, paper, ink, reset everything but the page is waiting in a...
Hello and Welcome to FixYa!
The "Printer not responding" message may appear due to many reasons like;
  • Bad connection
  • Printer Malfunction
  • Bad Communication port
  • Faulty Drivers
  • Printer Spooler not active
As you have stated you have had checked the connections, and also have reset the printer, so going straight to Drivers and Spooler issue.
I'll advise you to navigate to this link, detailed step by step guidelines are mentioned there; Vendor's support page. (Step 5)
If you are on MAC OS-X, this is the support link.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 06, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
HP color laserjet 1600 wonte printe new toner color.
The supply status report is based on what the kill chip is reporting to the printer. If that particular color is not printing then it is likely that current is not flowing though a particular component in the cartridge. I would return the cartridge and get a replacement.
Feb 02, 2010 | HP Office Equipment & Supplies
Copying on the 930
replace your roll, if you havent use for quite some time, chances are this could be overexposed
Aug 30, 2008 | Brother FAX 930 All-In-One Thermal Printer
Printer is out of memory is ther solution to this
Hi 92366, If your printer all of a sudden started giving you ?out of memory? errors while printing things you could print before, then you might have a problem. First thing to do is print out a copy of your printers configuration and verify how much memory the printer thinks it has. If it?s different from what you physically installed you may have issues with you memory. If you are trying to print large graphics they you simply may just need to increase you printers memory. If you?ve got plenty of memory, you haven?t changed or done anything to cause this error and you?ve been able to print this material before without errors here are some things to try: The 5P doesn?t have a display screen I?m assuming you?re getting this error in Windows. What is the status of the LEDs on the printer when you get this error? If you or anyone else with a similar problem is so inclined here is HPs LED code sheet: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl04302 Try deleting your existing printer queue, downloading a new copy of the appropriate driver and reinstall. Here is the link to the HP site, simply select your operating system, select and download the appropriate driver. I personally am more partial to the pcl 5e driver and avoid everything else, in particular the PostScript drivers. Here is the HP link for their LaserJet 5p drivers: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=15011&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25481&debug=Keynote If none of this works let us know what happened that seems pertinent. Good luck and please don?t forget to rate the posting.
Jan 12, 2007 | HP LaserJet 5p Printer
HP DeskJet 930c InkJet Printer Logo
103 people viewed this question
Clive
Clive
