LG 50px950 no connection from HDMI connections. This is a 2010 TV and it was working fine before. Currently I can connect a working DVD player and a working Dish box to it and the TV can recognize that there is a connected HDMI cable but will not display a picture. TV reports "No Connection"
snakehead
  • 1074 Answers
SOURCE: HDMI Connection
to narrow it down get the right cable and do your connection.if it does not work have the cable company take a look at your cable box.if that dont work then you can safetly say it is your tv.then it will be time to call in the repairman.
Posted on Mar 30, 2007
SOURCE: I'm simply looking for the
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Posted on Jan 10, 2009
  • 23 Answers
SOURCE: HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Posted on Feb 17, 2009
lightnbaby
  • 36 Answers
SOURCE: No Picture on LG 50PC3D
No power?
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least!
Posted on Mar 15, 2009
rylee_smith
  • 8619 Answers
SOURCE: HDMI input does not work
Hi
Thanks for using FixYa. Two things may cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts. Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
Lg 42lt75 used to work with a bp630 blue ray player but now shows "No Signal".
have you tried connecting ur laptop via hdmi to tv? if it works you should probably check tv settings for hdmi, if not then it is possible that the hdmi controller from tv to have some problems, i had a similar problem with a philips tv and took it to service ending up in a total replacement of motherboard and led display
Mar 09, 2014 | Televison & Video
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
The picture on my LG 50PX950 disappeared.
Your description suggests a power supply problem
Feb 28, 2013 | LG 50PX950 50" 3D Plasma TV
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
How do i connect my lg video to my lg tv
Hi! If your TV does have HDMI (as your DVD) then this will be without doubt the best way. You will be getting great image quality and there is zero configuration needed. Just connect them by HDMI and select HDMI INPUT on your tv
Also, by using HDMI, and since both devices are LG, you will realize you can use one special button you can locate on both your remotes, it's called simplelink. Pressing this button will allow you to use some special features not available with another connection.
If you can go this way you will realize configuration is pretty straightforward and, in no time, you will have your whole system working ;)
Miquel.
Mar 05, 2011 | LG DBRH197H DVD Player/HDD Recorder
Maxent tv has trouble with connection to dvd players
Tries change another HDMI cable.Go to the tv menu,go to PICTURE,go down to reset.The Tuner board should reset itself back to the Factory setting.It should work now.
Jul 12, 2010 | Maxent MX-50X5 Television
Hdmi switcher
First check individually if they work ,then connect to HDMI switch ,then change the position of the switch if it is a manual switch or connect the cable to the dish and check the dvd works...............
May 29, 2008 | Toshiba HD-A2 HD-DVD
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Electro Med Services...
