Question about Xerox WorkCentre XL2140df Laser Printer
Have a workcentr xl2140df printer and no driver for it to work on for windows7 64 bit
    New Friend:
  • 38 Answers
Go to this website www.support/workcentre-xl2140df-copier-laser-printer/downloads/enus.html?operatingSystem=winxp
You should be able do download the most current driver
Posted on Oct 10, 2013
4 Suggested Answers
SOURCE: troubleshoot xerox workcentre xl2140df
thank you
Posted on Jan 21, 2008
  • 17 Answers
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Posted on Apr 03, 2010
  • 2072 Answers
SOURCE: Problem connecting Win 7 64-bit
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Posted on Jan 28, 2011
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
I've lost my user guide and need a new one. Where to get?
You can get the user manual for this unit from this link, just click HERE and also HERE.
Sep 14, 2010 | Xerox WorkCentre XL2140df Laser Printer
Getting message H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jul 30, 2009 | Xerox WorkCentre XL2140df Laser Printer
Jul 01, 2009 | Xerox WorkCentre Pro 423 Copier
Tonor along edge of paper on my Xerox WorkCentre XL2140df
I would think you just have another bad cartridge. have you simply tried shaking it side to side? May just be built up on one side, but those cartridges are notorious for going bad. You need to vacuum the machine out well also. That toner and developer get in all those little plastic supports and can cause toner to dump.I would say the chance of a bad cartridge again is about 95 percent.
The printing problem. Have you tried downloading the driver from the Xerox.com site? Or simply reloading the driver. Sounds like its corrupted somehow. And when you change the tray, you are clicking apply?
Dec 17, 2008 | Xerox WorkCentre XL2140df Laser Printer
HELP HELP HELP HELP NOW! We are making copys on a Xerox XL2140df and it is blinking a red squigly light..... it won't print.  Flashes E.. help us. We need the copies ASAP.
OK first don't panic, Second the Squikly line ( does it look like a lighting Bolt sort of ?
this means you have paper stuck somewhere and and it needs to be removed.,Open the cassette and remove paper then open the side door then the front door and remove paper that is stuck ( BE CAREFUL not to touch the GREEN ROLLER THING ) thats called a Drum, you do not want to scratch that ok.
Nov 18, 2008 | Xerox WorkCentre XL2140df Laser Printer
Troubleshoot xerox workcentre xl2140df we have an error code E5?
An E-5 Normally comes from the paper path actuator that detcts the second side of a copy is hanging up.
In the fuser area there are some corrigated looking parts of the fuser exit guide that the actuator is most likely hitting or hanging up on.
You may have to take a pair of diagional cutters and snip a small section of that out.E-5 is a jam on duplex copies on that machine.
Jan 12, 2008 | Xerox WorkCentre XL2140df Laser Printer
Xerox WorkCentre XL2140df Laser Printer Logo
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
