Question about HEWLETT-PACKARD Hewlett Packard Pavilion PC HP Pavilion DM3-3011nr : 1.2GHz Pentium Dual Core 13.3in display BD-DM3-... (BDDM33011NR) PC Notebook
Pavilion dm3-3011nr no wireless adapter detected? Only shows wired connection & keeps telling me to plug in the ethernet cable. My router is working fine- how do I connect to the Wifi?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
Download iobit.com driver booster and run it for free to upgrade and get the required drivers for you notebook
Posted on Nov 16, 2013
KittyTech
  • 324 Answers
SOURCE: I have a new HP Laptop G56 runing windows 7, when
Try a hard reset on the router first;
Turn router around;
Find the small pinhole usually located by the power cord;
Stick something like a paperclip in it and press down firmly for 1 minute;
wait until you see the lights blink and then go out;
Then; unplug the power cord from router for about half a minute;
Then, plug it back in.
Try it again and see if it stays on.
You can also try and upgrade your firmware if this doesn't help at all.
Click this link and follow the instructions for updating your firmware.
http://forums.whirlpool.net.au/archive/322832
However; If your router is old or damaged, it may need to be replaced. They shouldn't continue to reboot over and over.
Please rate this solution if it was helpful to you. It doesn't cost anything to rate and it is greatly appreciated!
KittyTech
Posted on Jan 06, 2011
jagojay
  • 200 Answers
SOURCE: my computer wont puck up any wireless connections it doesnt even show the adapter anymore i don't know what happened can anyone help??
Could be an error with the wireless assistant or maybe a corrupt wifi driver. The following link is for the HP wireless assistant, try downloading and installing it:
http://driverscollection.com/?file_cid=41965100331997a97689ea2d723
This is the link for HP support where you can try downloading a new wifi driver. You will need to know what wifi adapter is installed to get the correct driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=4146525&prodTypeId=321957&prodSeriesId=
4113092&swLang=13&taskId=135&swEnvOID=4062#11395
Posted on Apr 09, 2012
SOURCE: wifi not working in windows 7
Good ole Windows 7, just a tad bit better than Vista. I would never get rid of my Windows XP Operating System to be on either of those unstable operating systems.
OK, so are you near the wireless router, if not go near it and then try to connect. If you don't see it as one of your available wireless networks, then you have to make sure that the Wireless Switch is turned on.
If you are sure it is turned on, then there are also keystrokes that turn the wireless on and off. Normally you would Press and Hold the FN function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key will have the wireless icon on it such as )))) or it might be a tower with ))) around it. Normally when you toggle the wireless by keystrokes your screen will display something like Wireless On or Wireless Off.
If you still have problems download and reinstall the wireless drivers.
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Wireless drivers.
Posted on Apr 19, 2012
rwoods142
  • 119 Answers
SOURCE: Hdmi not detected by HP Pavilion dv5-1235dx Entertainment Notebook PC
You may want to check your dispaly properties to make sure that your display is set to HDMI instead of laptop display in the control panel under display properties. On many laptops, this can be done by pressing the "fn" key and a key with a blue symbol of two screens on it. This toggles between your primary display and external ones.
Posted on Nov 23, 2012
  • 564 Answers
SOURCE: How to fix wireless connection problem with pavilion dv4015cl laptop using intel PRO/Wireless 2200BG Network Connection
if you open up a command prompt (if you're using windows 7 just click start and type cmd then right click the icon that comes up and choose run as administrator, if using xp click start and you should see command prompt and do the same.) when the window opens type ipconfig and press enter. look at your ip address, if it starts with 169 type ipconfig /release and press enter wait for it to do that then type ipconfig /renew and press enter. check your ip address again, it should start with 192. then close the window and try to open the web browser.
Posted on Dec 07, 2012
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
"Ethernet cable unplugged"
A few things to try. Plug the cable into a different port on the router to rule out a bad port on router. Try a different ethernet cable (they do go bad). If this is an older router it may not be able to do logic swap on the pins and you would need to use a cross-over cable and not a straight through. Also check in device manager and make sure the computer is not allowed to disable the lan adapter in power saving mode. Also if your really want you can test your ethernet port by buying or making your own loopback plug. Look up ethernet stander T568A. You basically would buy a empty ethernet jack and run a short wire from pin 1 to pin 3 and a wire from pin 2 to pin 6. This will simulate sending data to another device (the other device will simply be the receiving pins on your own ethernet jack.
Feb 02, 2012 | Microsoft MN-820 802.11g/b (r88-00001)...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Laptop died and now I cant connect my desktop with the belkin usb adapter. It just keeps saying aquiring network address.
Use the Ethernet cable to verify the router or modem is working and connects to the Internet. If so, then check your wireless adapter in the desk top through device manager - it should detect the Belkin. Also, verify you are entering the correct WEP keys to access the wireless connection to the router or modem - sometimes it gets typed in wrong.
Feb 19, 2011 | Belkin (F5D7050) 802.11a/g/b Wireless...
D-Link Wireless Router WBR-1310 wont connect?
- Check LAN cable
- Use a different cable
- Use "crossed" LAN cable
Oct 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Oct 17, 2009 | Microsoft Wireless Network Adapter Xbox...
No internet connection and Ralink Wireless Adapter Not Exist
try it to connect in other slot check if there is dust or rust ,clean it ,make sure your adpoter is conttected properly and check biose setting than expantion slot enabled (if there is a
Jul 22, 2009 | Computers & Internet
Ethernet connectivity problem.
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Right-click Local Area Connection, and then click Properties.
  3. On the General tab, click Configure.
  4. In the resulting dialog box, click the Advanced tab.
  5. In the Property list, click Media Type or Link Speed & Duplex or something similar.
    Note If these properties do not appear, look for a property that has the values Duplex and Half-Duplex.
  6. Click a specific bandwidth in the Value list, and then click OK.
  7. Close the Network Connections dialog box.
  8. Test the network connection.
  9. If these steps do not resolve the issue, repeat steps 1 through 5, and then click a different value in step 6 until you have tested all values.
Check if that works.
Jul 19, 2009 | Dell Ethernet Card Network Adapter
Ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
Jun 02, 2009 | NetGear WGR614 Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
HEWLETT-PACKARD Hewlett Packard Pavilion PC HP Pavilion DM3-3011nr : 1.2GHz Pentium Dual Core 13.3in display BD-DM3-... (BDDM33011NR) PC Notebook Logo
98 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
