Question about Furniture
Our KitchenAid under the counter wine cooler is not cooling. The light goes on when we open it and I occasionally hear the motor running as well but doesn't seem to be much, if at all, colder at those times.
  • 3,228 Answers
Some folks like to speak "typical" & "in general..."
I prefer Fahrenheit... with model numbers
e.g. KITCHENAID, model KUWS24RSSS 14...
is an AMERICAN made gorgeous.. stainless steel 2 zone... pullout shelf UNIT that my wife was dying to get...
Now it's killing me.
NOT CHEAP... fully warrantied ... REALLY BIG PRICE...
REALLY no CUSTOMER support (I input multiple complaints/appeals for info/assistance & never got a boo or howdy back from anyone (my opinion... my wasted money...
(my warm wine)).
Cheesy ... poorly constructed and shabby design
(few parts available... ZERO response from
KITCHENAID...
FAN bracket was designed to be in direct conflict
with the refrigerant return line... if INSTALLED CARELESSLY...
which of course It WAS.
It took about 5 years and 2 months to wear a hole into the ALUMINUM return side of that SAD little aluminum evaporator,
The shelves should be labelled and simply lifted out.
Electronic refrigerant sniffer would be used by the professionals to locate the precise leak source (Amazon & Granger retail these items, see below)
Or... After you attach the self piercing SUPCO valves
You can prove the fault by attaching a refrigeration vacuum pump
and some REFRIGERANT GAUGES (also below) simple piece of duct tape... Meaning you will be looking at either trying to cut and fit an after-market coupling onto a straight section... or you are going to learn aluminum BRAISING.
SERIOUS CAUTION...
Aside from the chance of melting the plastic interior... there are the additional deadly gases that can be released by a flame & Freon.. and a flame and styrene plastic insulation (deadly
(vent really WELL or don't worry about results)).
Protect surfaces with ceramic soldering shields.
The whole "cooler" only needs a can of R134
(autoparts store, Amazon, eBay... or harbor-freight).
Always wear gloves and goggles...Be safe!
Hope this helps.
https://www.grainger.com/product/SUPCO-Refrigeration-Line-Piercing-WP6306846/_/N-k00Z1z0r1c0?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/6X898_AS01?$smthumb$
https://www.grainger.com/product/3KRF5?cm_re=AZIDPRR&cm_sp=Product_Details-_-Customers_Also_Viewed-_-AZIDPRR_46998&cm_vc=AZIDPRR_46998
Welding-Protective-Blanket-
Amazon com HiwowSport 18 24 inches High Temp Carbon Fiber Welding...
R134 gauges & pumps (check for CENTIGRADE (CELCIUS)).
(Display only... check for Fahrenheit (not metric)).
Amazon com HVAC Single stage Rotary Vane Vacuum Pump 3CFM 1 4HP...
Posted on Nov 25, 2016
    New Friend:
    Problem Solver:
  • 5 Answers
Its simple just add the freezing timer or air conditoner
Posted on Oct 10, 2013
  • Lydia Alexander
    Lydia Alexander Oct 10, 2013
    Do you mean add coolant or fix the thermostat on the wine cooler?
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
  • 286 Answers
SOURCE: U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Posted on May 18, 2009
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
The wine cooler doesn't seem to be cooling light goes on when you open door so pretty sure it has electricity to it?
Can you hear it running? If there is a question, leave the door open and remain there until you hear it start. This may take up to 15 minutes.
What do you have the control on? Wine coolers ar not refrigerators. (White) wine typically served at cellar temp (around 50 to 55 degrees. My friend, please don't tell me you are chilling quality Reds! You are killing them.
Thanks for your interest in FixYa.com
Jan 29, 2011 | GE Monogram ZDWT240PBS Wine Cooler
Model # KitchenAid KUWA244PBSO Wine Cooler is not cooling, however the light comes on when the door is opened.
Might need to replace the thermostat, which is easy to do (repairman not required).
Youtube demonstration for the Kitchenaid kuwa244PBS0 model posted here:
Jun 29, 2010 | KitchenAid KUWA244PBL Wine Cooler
Light comes on when you open door but wine cooler does not come one (does not cool). Checked all circuit breakers.
check thermostat set it to the coldest setting if doesnt come on test stat for power if power jump stat see if starts if still doesnt test for power at compressor if power than check thermo safety for compressor if good than compressor has an internal problem which will probably require a replacement
May 15, 2010 | KitchenAid Architect KUWA244PSS Stainless...
Wine cooler just stopped working. light will come
Try disconnecting all power to the unit for about 10 mins, and turn it back on to see if the compressor will kick in. Also check your temp settings and make sure they are properly set. If that doesnt work, you might have a dead compressor which a tech can look at and verify.
DrakeTech.
Mar 01, 2010 | KitchenAid KUWS246E Stainless Steel Wine...
It is not cooling. Not running. It RARELY gets opened, recently opened the door and found it was not cooling. Doesn't even appear to be running.
If your unit doesnt run and no fan or compressor then replace the thermostat. That would be the only thing that turns on the compressor and fan
Aug 11, 2009 | KitchenAid KUWS246E Wine Cooler
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Nov 25, 2008 | U-Line 15WC Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
Avanti Wine Refrigeraator
thanks for the question i think the problem is that its under the counter no air flow to cool the coils try it not under counter thanks the appliance doc
Sep 24, 2008 | Danby DWC283BLS Wine Cooler
Furniture Logo
261 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
