Question about LG L1717S-BN 17" LCD Monitor
LG L1717S has no light
My L1717S monitor turns on for a split second and then goes dark again, but it still shows what it is supposed to show just very , very dark (you can only see in bright light at an angle). The power on light is green. I opened up the plastic base but could not find a way to open the screen it self. It did turn on normally one time but even then it only lasted for something like 10 minutes.
    Scholar:
  • 106 Answers
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Posted on Apr 23, 2009
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Dec 10, 2009 | Computers & Internet
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Hello I am facing a problem with my monitor LG L1717s the last days. I have set my monitor never to close, no screensaver etc. But when I go to my pc after 8 hrs monitor has the green light but it seems to...
Think it fell into a really deep sleep. Unplug the monitor for 20 minutes and try plugging it in again and then re boot your computer and see if that works for you.
Aug 05, 2017 | LG L1717S-BN 17" LCD Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
MONITOR SWITCHES ITS SELF OFF
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it turns itself off, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken. The lamps are very easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 13, 2008 | LG L1717S-BN 17" LCD Monitor
Flatron l1717s blank screen
Common cause of this is the VGA or DVI connectors not screwed on tight on either the back of the PC or the back of the monitor.
Also try removing power by unplugging for 30 seconds, sometimes that will reset things.
Feb 16, 2008 | LG L1717S-BN 17" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
LG L1717S-BN 17" LCD Monitor Logo
635 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
