Question about Refrigerators
Our Kenmore 795.76202.901 was not cooling this morning and the digital temp controls read ERR and FF. The freezer seems to be working fine. We pulled it away from the wall and immediately I saw where a mouse had chewed through a ground wire. I fixed the wire and now the controls are reading as they should, however the fridge is not cooling and the compressor has not kicked on.
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
  • 531 Answers
SOURCE: Kenmore Elite Bottom Freezer Refrigerator Control Pad problem
check your service manual and see what it say about err ff
Posted on Apr 02, 2009
  • 363 Answers
SOURCE: fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Posted on Jul 26, 2009
  • 15 Answers
SOURCE: The temp on the door reads very cold, ie. -10
Sounds like you have a defective thermistor....The problem is there are 4 that deal with Fridge and Freezer compartments...There are tests that you can run from the display panel. You will not hurt anything by trying the tests...It is too difficult to explain the tests but here is a link a pdf for the RB215 that will help you if you or someone can follow directions...
Most servicers don't have a clue about this stuff....bummer
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Posted on Apr 12, 2010
Fridge freezer gets warm every 24/48 hours
A few things to consider. What is he temp in the FF side of the unit? Putting a thermometer in a glass of water overnight on the bottom shelf should read 40F in the morning. If that's fine its cooling properly. Assuming your not opening and closing the doors excessively, you could have a leaking/bad door gasket or the interior light door switch has failed and is stuck in the on position, which would make the interior temp slowly rise. To check the door gasket, close the door on a dollar bill (at various places around the doors), slowly pull out the bill you should feel good resistance,, if it pulls out easily or no resistance is felt the door gasket is bad or door is misaligned. Also don't forget door gaskets and sealing surfaces need to be checked and cleaned regularly for them to seal properly.
Nov 04, 2014 | Refrigerators
My kenmore side by side refergerator is not cooling like it should. My freezer is working fine. The compressor seems to be working but it is hot. My cooling fan is working fine. My thermostats seem to be...
I dont know if you have a newer or old model(thanks for NOT including model# in your question) but if its fairly new their very likely is a damper door in the upper left corner of the fresh food compartment that opens to let air into the FF compartment when it needs it. That damper (if it has one) is not opening.
If that damper is opening..is thier frost build up on back wall of FREEZER? if thier is frost build up its not defrosting automatically ,and that build up frost is blocking air flow into FF section.
Aug 24, 2011 | Refrigerators
Freezer not working digital read out is err and ff
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | LG LRSC26910 Side by Side Refrigerator
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Elite ER FF
Possible sesor error. Unplug for bout 10 min then plug back up.
Jan 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
