Question about Microsoft Windows 7 Ultimate for PC
Need to download rt120.bpl - Microsoft Windows 7 Ultimate for PC
    Scholar:
  • 154 Answers
1. When are you getting this error message?
2. Have you made any changes to your computer recently?
3. What is the exact error message you receive?
I would suggest you to follow the steps and check if it helps.
Method 1:
Step 1:
Login to Safe Mode and then check if it helps.
Start your computer in safe mode
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Step 2: Perform a clean boot and then check if it helps.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
NOTE: Make sure that you perform "step 7" in the link mentioned above to boot your computer normally.
Method 2: Scan your computer for virus using Microsoft Security Scanner and then check if it helps.
Microsoft Safety Scanner
http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: Any data files that are infected may only be cleaned by deleting the file entirely, which means there is a potential for data loss.
Hope this helps.
Posted on Oct 16, 2013
Wen i start my HP 6730b laptop a tab coms up saying,,,,,rt120.bpl ,,is missing,,how do i fix this problem???,,,thnx
1. Start your computer in Safe Mode (hold in f8 on startup - Choose "Start in Safe Mode").
2. uninstall the program "TuneUp Utilities 2010"
3. The problem should now be gone.
May 15, 2014 | HP Compaq 6730b Notebook
Download rtl120 bpl
rtl120.bpl will be in OS. Might be it is corrupted. Please format C: drive. So error will be rectified
Jan 29, 2014 | Microsoft Computers & Internet
Want to download rtl120.bpl
Do you remember what is the last program you installed on the computer? If it is TuneUp Utilities, try to unistall them and see if that fixes your problem.
If you need any additional help, let me know.
Jan 03, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Need to download dll file rt120.bpl
Method 1:
Step 1:
Oct 10, 2013 | Microsoft Windows 7 Ultimate for PC
My computer says I must download rt120.bpl where can I find this to download for free
This file appears to come from a third party program called advanced system care. It is not a part of windows 7. google search for it download and reinstall it to see if this fixes it.
Oct 17, 2012 | E-Machines Computers & Internet
Rt120.bpl shows up as missing
Try running the check disk utility.
To run the check disk utility you will need arepair disc or a operating system disc. Put the disc in the cd drive andboot from it. You want to get to the Dos Command Prompt (Black screenwith white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vistaand Windows 7 you want to get to the recovery console and look down at thebottom of the window for the D
Sounds like you need to reinstall windows. Try doing a Repair Install to save all your data.
Apr 13, 2012 | HP Computers & Internet
Rt120.bpl shows as missing
To run the check disk utility you will need are pair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vistaand Windows 7 you want to get to the recovery console and look down at the bottom of the window for the D
If Check disk does not remedy the problem, Sounds like you need to reinstall windows. Try doing a Repair Install to save all your data.
The program can't start because rtl120.bpl is missing from your computer. Try reinstalling the program to fix this problem.
Google 'download rtl120.bpl'.
Download the file from the list and put it in C:\WIndows\System32
You may be asked for other libraries too. Just do the same thing to get them.
Jun 19, 2011 | Computers & Internet
Rtl100.bpl not found free
Hello Estherc54,
If you got rtl100.bpl error then there are chances that your computer has registry problems. To repair rtl100.bpl error you need to follow the steps below:
  • Step 1 - Choose a rtl100.bpl error repair tool,download and install rtl100.bpl error repair tool Scan for FREE.
  • Step 2 - Click the Scan Button.
  • Step 3 - then click the Fix Button and your done! It is very easy to repair rtl100.bpl error.
  • URL : http://www.fixerrorfast.com/ttfix-rtl100.bpl_error-zz0001
    Best tools : Regcure, Perfect Optimizer
    Regards,
    soul_srch007
    Dec 05, 2009 | Microsoft Windows XP Home Edition
    Microsoft Windows 7 Ultimate for PC Logo
    70 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
