Question about Panasonic Technics Sa-505 Stereo Receiver Brochure
Technics sa-505 stuck in protection mode - Panasonic Technics Sa-505 Stereo Receiver Brochure
I have a Technics SU-G91 amp that is stuck in overload even with no input. I have tried giving it a quick blast of air to dust and still nothing. All help is appreciated!!
Your Technics unit will remain in the overload (protect mode) state until component failures have been corrected. The output stages and/or associated components may have failed.
Sep 02, 2016 | Technics Audio Players & Recorders
Why am i getting an overload message when i don't have anything connected to it ?technics sa-dx 1040
double check there isn't a piece of wire that has broken off the speaker cables and is shorting two of the speaker terminals together. The unit needs to be turned off and unplugged for a minute to reset the protection circuitry. If this doesn't fix it, there's likely an internal failure.
Dec 22, 2014 | Technics SA-DX1040 Receiver
How can I repair my Technics SA 505 Receiver ?
Hi Mark,
Start opening up the receiver and look for possible burnt cmponents.
pictures may be of help, if you need assistance in troubleshooting
your receiver.
Only if you feel you can DIY.
Oct 28, 2012 | Technics Audio Players & Recorders
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
Technics sa-dx 950. F70 on display. ???
This is a shorthand version of protect. See the link below. If you have more questions, please post them here and I'll respond.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Aug 21, 2010 | Technics SA-DX950 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
Divinci DV 208
I have a problem with my divinci dv-208 the protect button just started coming on and wont go away!
Oct 20, 2007 | Technics SA-AX720 Receiver
Panasonic Technics Sa-505 Stereo Receiver Brochure Logo
109 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
