Question about Microsoft Windows 7 Ultimate for PC
Need to download dll file rt120.bpl - Microsoft Windows 7 Ultimate for PC
    Champion:
    Habit-Forming:
  • 245 Answers
I would suggest you to follow the steps and check if it helps.
Method 1:
Step 1:
Login to Safe Mode and then check if it helps.
Start your computer in safe mode
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Step 2: Perform a clean boot and then check if it helps.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
NOTE: Make sure that you perform "step 7" in the link mentioned above to boot your computer normally.
Method 2: Scan your computer for virus using Microsoft Security Scanner and then check if it helps.
Microsoft Safety Scanner
http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: Any data files that are infected may only be cleaned by deleting the file entirely, which means there is a potential for data loss.
Posted on Oct 18, 2013
Wen i start my HP 6730b laptop a tab coms up saying,,,,,rt120.bpl ,,is missing,,how do i fix this problem???,,,thnx
1. Start your computer in Safe Mode (hold in f8 on startup - Choose "Start in Safe Mode").
2. uninstall the program "TuneUp Utilities 2010"
3. The problem should now be gone.
May 15, 2014 | HP Compaq 6730b Notebook
Iam missingrtil120.bpl
A bpl file is not a windows dll.
Nov 19, 2013 | Computers & Internet
Need to download rt120.bpl
1. When are you getting this error message?
2. Have you made any changes to your computer recently?
3. What is the exact error message you receive?
Method 1:
Step 1:
Hope this helps.
Oct 10, 2013 | Microsoft Windows 7 Ultimate for PC
Install download rtl 120bpl for laptop hp
Here is a download for the 32-bit version:
http://www.down-dll.com/index.php?file-download=rtl120.bpl
Dec 09, 2012 | HP Computers & Internet
My computer says I must download rt120.bpl where can I find this to download for free
This file appears to come from a third party program called advanced system care. It is not a part of windows 7. google search for it download and reinstall it to see if this fixes it.
Oct 17, 2012 | E-Machines Computers & Internet
Rt120.bpl shows up as missing
Try running the check disk utility.
To run the check disk utility you will need arepair disc or a operating system disc. Put the disc in the cd drive andboot from it. You want to get to the Dos Command Prompt (Black screenwith white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vistaand Windows 7 you want to get to the recovery console and look down at thebottom of the window for the D
Sounds like you need to reinstall windows. Try doing a Repair Install to save all your data.
Apr 13, 2012 | HP Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Microsoft Windows 7 Ultimate for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
