Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Refrigerator door will not close. - Admiral 26 cu. ft. Side-By-Side Refrigerator
  • 146 Answers
Please make sure that the door gaskets are not damaged twisted around or hunging also make sure the drawers are all the way in this is the only thing that will prevent from door closing or too many items and something may stick out like bottles or milk gallons.
Posted on Dec 08, 2013
Why won't door on Samsung side-by-side refrigerator stay closed? Pops open after closing, like the seal isn't working.
The door isn't lining up right when it's closed. I suspect you have been putting heavy stuff on the door racks, like several 2 liter soda bottles or gallon jugs of milk. Over time the door will sag from the weight until it won't stay closed.
Nov 06, 2014 | Samsung RSG307AABP 30 cu. ft. Side by Side...
I have top freezer LG refrigerator (I have it for a week, so it's a brand new). When I close refrigerator door the freezers door bounces opens and closes). Hoe to fix this problem?
When you close the door, the air pushed in by the door has to do somewhere, so it may momentarily pop the other door. As long as it closes right away by itself, no problem.
Apr 19, 2011 | LG LRTBC1825T Top Freezer Refrigerator
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Refrigerator gurling noise when door closes
There is a water evaporation tray in the back of the frig. Air pressure fron closing door makes air bubble thru tray. Its not a problem.
Aug 28, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRT17G4BW9 doors not staying closed
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Kitchenaid refrigerator side by side, refrigerator door will not close on its on like it use to. Model #KSRS25qDWH01 bought in 1996. If we give it a push it closes fine. But it use to close nearly b
order a cam and stop for the affected door. it is on the top of the hinge and the bottom of the door, you'll see the two pieces if you look where the door contacts the hinge, call a dealer for the correct part numbers.
May 04, 2009 | KitchenAid KSCS25FKSS Side by Side...
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Mar 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
56 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
