Question about HEWLETT-PACKARD HP 1TB USB 3.0 Portable USB 2.0 Hard Drive
HP 1TB USB 3.0 Portable USB 2.0 Hard Drive, driver
HP 1TB USB 3.0 Portable USB 2.0 Hard Drive, driver will not be recognized on 2 computers. has not been dropped or submerged
    Novelist:
    Scholar:
  • 100 Answers
If you run Windows, there's a chance that Windows installed it's own driver for this device. Sometimes you better install the driver of the manufacturer (Hewlet Packard). Try to download it from the HP-site.
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home/?lang=en&cc=emea_middle_east&sp4ts.oid=5383421
If all fails, it might be a hardware-issue, and this makes it a better idea to contact HP for customer-support.
Posted on Oct 18, 2013
2 Suggested Answers
falachen121
  • 55 Answers
SOURCE: want to install my 2tb
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program called asoftech data recovery to recover your files. you can find it from facebook
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Posted on Dec 14, 2012
How can I retrieve saved data from my Transcend 2.5 StoreJet Portable HDD
Remove the drive and connect it to a known good USB adapter. If it still won't be recognised, buy a new drive. Sorry.
Jul 19, 2014 | Transcend 1TB 2.5 Inch StoreJet Mobile H2...
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Jan 03, 2014 | Western Digital 1TB My Passport Essential...
PC will not recognize the external harddrive passport. PC has been rebooted and passport has been unplugged and replugged to get PC to try and recognize passport. Light on the passport comes on, and the...
3 beeps its searching for a connected device
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 13, 2011 | Western Digital 1TB My Passport Essential...
Western Digital 1TB My Passport Essential SE USB 3.0 Portable External, WDBACX0010BBKSN USB 2.0 Hard Drive not recognised
Hi there. Here are some solutions you could try 1. Try connecting it with a different USB cable as the present one may be faulty. 2. If you can open the casing, do so to confirm if there is a loose connection. 3. You can try this great application tool from Seagate called Sea Tool. You will need to download and install on your computer. This tool examines you hard drive and lets you know if it is totally damaged. You can download it here. SEATOOL
Sep 06, 2011 | Western Digital 1TB My Passport Essential...
500 MB data error(cyclic redundancy check) external hard drive is not accessible
1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
2. This issue could be due to the data controller on the USB drive being defective.
3. try purchasing a new case with a new controller board.
4. Check to see if your 1TB USB drive is compatible with your pc.
Jun 13, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
Well my problem is that my Iomega eGO usb 3.0, 1TB is not being recognized by my computer. when I connect the hard drive via usb 3.0, the computer doesn't recognizes it. I'm using the Conceptronic Pc...
you might have to uninstall the express card restart your computer then reinstall it also make sure its clean and securely seated and there is no dust built up or it might be trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
ports(com&lpt)right click update driver hope this helps
Mar 23, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
My laptop doesn't recognize Lacie Rikiki Go 1TB. I have USB 2.0; and I couldn't find the drive in the Computer folder. Please help.
Hello roblau99:
First lets try this. Shutdown your laptop and reboot. Once your up and running, plug in your portable hard drive. You might try a different USB port. If windows doesn't let you know its there then you need to look for it by going into your administration tools menu. Of course this depends on what version of windows your are running, if it is windows.
Maybe you can answer this? Have you been disconnecting that hard drive without telling windows you are going to disconnect it first? If the answer is yes you may have corrupted that drive which is why windows is not recognizing it.
Good Luck and just let me know if you need more help.
Sincerely, Peter N.
Mar 22, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
HEWLETT-PACKARD HP 1TB USB 3.0 Portable USB 2.0 Hard Drive Logo
147 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
