Question about Ricoh Aficio 450 Copier
Functional Problems SC350 - 01 Turn On/Off Switch off the On If the error appears agian Call: Service; 00 - 0000 - 0000
I have recently provided a post to the same problem. Please note that the Power must be turned off with the "main power" (red button) to reset.
The link is here:
http://www.fixya.com/support/t1999925-sc350_01_error_code
Please let me know if this helps, and rate my solution :)
Posted on Apr 23, 2009
Ir3235 canon system code E000002-0000 Solution to fix this problem
Hi. That error is related to the fixing unit. You need to clear it from service mode first.
You need to be quick doing the next process because machine will automatically turn off after a few minutes.
With the copier turned on press the next key secuence
Press adittional function
Press 2 and 8 ( at the same time )
Press additional function.
Service mode should appear in the screen . If it doesn't repeat the secuence until it does .
When service mode appears press in the touch panel COPIER
Then select FUNCTION
Then select CLEAR
then select in the lower list ERR
Then press ok in the lower corner
Turn off the machine from main Switch. Wait a few seconds and turn it on again .
Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced.
Mar 30, 2017 | Canon ImageRUNNER 3235 Black and White...
Hp 500ps severe error code Ox40d0003-
If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
    NOTE: Always verify the printer's current Firmware release and upgrade as needed.
    1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
    2. If the error appears or problems persist, continue with the remaining steps.
    3. Turn the printer off, and disconnect the power cable.
    4. Remove the right end cover.
    5. Check both Ink Supply Station connections on the Interconnect PCA. If the unit shows the error on boot up verify that the connector with the blue wires is seated correctly (Connector P4). If the error appears when a print job is sent to it verify that the connector with the red, black and green wires is seated correctly (Connector P2).
    6. Reconnect the power cable and turn the printer on.
    7. If no error appears, attempt to verify functionality.
    8. If the problem persists, continue with the remaining steps.
    9. Replace the Ink Supply Station (refer to pg. 8-48 of the HP Designjet 500 and 800 Series Service Manual).
    10. Following replacement, attempt to verify functionality.
    11. If the error reappears, replace the Electronics module (refer to pg. 8-24 of the HP Designjet 500 and 800 Series Service Manual).
Jan 02, 2017 | HP DesignJet 500ps (42 in.) InkJet Printer
Please help me with my canon ir 2520 error code e000002. i am trying to solved it but it fails
hi. you need to clear that error from service mode first.
press aditional function
press 2
press 8
when #sssw appear on the screen search with arrows in the touch panel until CLEAR appear on the screen
press ok once
and search with arrows until ENGINE appear on the screen
press ok once
ERRCLR appears on screen . press ok one more time
turn off the machine from main switch for a few seconds
turn on again and make copy test .
if problem persist replace the fixing heater.
May 13, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
Photocopy IR2230 error code 0001/0002
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Jun 02, 2014 | Canon imageRUNNER 2200
Print head
The carriage does not accept one or more of the printheads. Typical causes are dirty contacts on the printheads or carriage, defective printhead(s), or a defective carriage.
If parts are replaced or fixed in any of the steps listed below, attempt to verify printer functionality by turning the printer on and printing internal test prints. If functionality is verified, no additional parts should be replaced.
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. With the printhead icon highlighted, press ENTER.
  4. Select Replace Printheads and press ENTER.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. Open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts on the carriage and the printheads using a lint-free cloth dampened with water.
  10. (for this step I suggest using the erraser on the back of a regular pencil instead of a cloth and water)
  11. Allow the contacts to dry.
  12. Reinstall the printheads and close the carriage cover.
  13. Close the top cover.
  14. Turn the printer on and attempt to verify functionality, as instructed in Step 19.
  15. If the error reappears, replace the affected printhead(s).
    NOTE: If the printhead error icon is a question mark, each printhead will have to be tested separately, as the printer is not sure which printhead is causing the problem.
    1. Following replacement of the suspect printhead(s), attempt to verify functionality (Step 19).
    2. If the problem persists following, replace the carriage and trailing cable (refer to pages 8-36 to 8-46 of the service manual).
    3. Following replacement, turn the printer on.
    4. Make sure the printhead alignment completes successfully and that no error messages appear on the front panel.
    5. Print a troubleshooting plot (as instructed below) to ensure the print quality is acceptable.
      1. On the front panel, select the printer icon and press ENTER.
      2. Select Utilities and press ENTER.
      3. Press the UP and ENTER buttons simultaneously.
      4. Select Yes to enter the Service Menu.
      5. Select Service Utilities and press ENTER.
      6. Print pages 1, 2, 3, 4 and 5 to prove printer functionality.
Mar 25, 2014 | HP DesignJet 5500PS InkJet Printer
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
I have a cannon ir 3300 machiene and occured a problem with a error code e000000-0000 please help me out to remove this problem my technician has asked me to change the filament which is worth 12000.w
select copier
select function
select "clear"
select "err"
select ok.
Feb 17, 2014 | Cannon Office Equipment & Supplies
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
419 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
