Question about Brother P-Touch PT-1830 Label Printer
How to print vertical on ptouch 1830 - Brother P-Touch PT-1830 Label Printer
Print vertical on the p touch 1830
You need to go to printer setting and go to print type. now you will able to see your paper printing type. you need to click on that and select A4 paper size.
Feb 21, 2015 | Brother P-Touch PT-1830 Label Printer
HOW DO I OIL THE DREMEL 1830 SCROLL SAW?
  • page 15 Squirt a generous amount of SAE 20 oil around the shaft end and bronze bearing
  • Dremel 1830 Manuals
Sep 16, 2014 | Dremel 1830 120V 18" Scroll Saw
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
When I print a label, there is a blank white space before and after the printed text. How do I reduce the amount of tape printed before and after the text so as to maximize the label tape available?
you can, change the margins to narrow. you'll decrease the right margin but not the left margin which accdg to my research, is the space needed for the ptouch to print.
May 31, 2010 | Brother P-Touch 1180 Label Printer
Change the print size
Go to this website and download a free manual. Should tell you how to increase the font sizes:
http://www.ptouchdirect.com/ptouch/umpt1180.html
Dec 19, 2009 | Brother P-Touch 1180 Label Printer
How can I change the language on my machine the brother p-touch?
Click here to get the manual.
Remove the batteries and disconnect the AC adapter if you do not intend to use the
machine for an extended period of time. (Note: When power is disconnected for more
than three minutes, all text shown in the display and any text files stored in the
memory will be lost. Language and unit settings will also be cleared.)
read Initial Setting as well.
In case the link fails
http://www.ptouchdirect.com/ptouch/umpt1830.html
http://www.ptouchdirect.com/ptouch/manual/PT1830.pdf
Oct 01, 2009 | Brother P-Touch PT-1830 Label Printer
QL 550 won't print
It has no ink as it is a thermal printer.   Make sure you are using genuine Brother Thermal Labels.
Mar 09, 2009 | Brother P-touch QL-550 Thermal Label...
Label Maker HELP!! Brother ptouch 1180
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Computers & Internet
Brother P-Touch PT-1830 Label Printer Logo
41 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
