Question about Coby TFDVD2295 22 in. LCD
Unable to switch to cable tv manually, and remote control no longer works. is there a code to reset the remote control?
How can I switch channel from Ant. Over to TV with no remote on a 2006 Sansai tv set
Every TV has buttons that can do all a remote does, check the user manual or google the make and model. user manual for instructions,
Nov 10, 2016 | Televison & Video
I have a bose universal cineomate solo 2 and I need the remote control code for my starview 7 digital cable recevier
About 66,600 results (0.76 seconds) Search Results
    STARVIEW HELP FILES ' AfterDawn Discussion Forums
    forums.afterdawn.com > ... > Home theater > Digital TV - UK & Europe
    Jul 6, 2007 - 11 posts - ‎3 authors
    Posting codes to the forums is no longer allowed. ... Connect your box and PC with a Null modem cable and switch on the cable ... 7. One of the listed ports should indicate which port your USB adapter is .... Using this method my Starview indicated it scanned 56/56 ... go to parental control in receiver menu Starview box
    Jun 15, 2014
    All New Starview HD Combo unit
    Nov 1, 2009
    STARVIEW UPDATING FIRMWARE - NO CODE ...
    May 14, 2008
    More results from forums.afterdawn.com
    Looking for a Universal Remote Control code (4-digit) to ...
    nordstromchicago.com/Looking_for_a_Universal_Remote_Control_cod...
    ... digital cable terminal? I need to reprogram my cable remote to operate my digital cable terminal. ... Code for Hugh button universal to control Dion free view box ... read more ..... I need the remote code for starview 7 remote control? Trying to ...
    Phantom Digital Cable TV Receiver. - TechKings
    www.techkings.org > ... > General Cable TV. > Phantom
Jan 28, 2016 | Bose Televison & Video
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
Coby TF TV 3227: unable to control volume
The post is a little unclear, but I will assume you are attempting to say that your remote works with the cable box but not the television.
If you are using the remote that came with the cable box, you will probably need to re-program it using the codes in the back of the cable box manual. If you are using a universal remote, you will still have to re-program it, but those codes are in the manual for the universal remote.
If you cannot find a code in the books, there is an alternate method of programming the remotes using a search function. The exact steps will be available in the respective remote manual.
Sep 06, 2012 | Televison & Video
Universal Remote: UR5U-8780L - Not Working and CBL Button Constantly Lit
press cable and record buttons at the same time and wait for all the lights to flash in sequence then let go. this will reset remote to factory defaults. then reprogram remote with codes for each device.here is a site for codes. http://www.universalremote.com/resources/pdfs/UR5U-8780L_UR5U-8790L.pdf
May 25, 2012 | Universal Remote Control Televison & Video
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Jun 01, 2009 | Kenwood Audio Players & Recorders
I'm unable to find a 4 digit device code for my TV remote
Best bet would be to contact the parent company to see about ordering a new remote
http://www.iwsolutions.com.au/contact.php
also if you check the back of newer universal remote cases in any electronics dept and see if your model can be programmed.
hope this helps :)
Nov 16, 2008 | Port Incorporated 2 Port Compact KVM...
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Coby TFDVD2295 22 in. LCD Logo
26 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
