Question about Samsung Washing Machines
WA13V5 CONTINUOUSLY FILLS WITH WATER AND STAYS ON FILLING
4 Suggested Answers
fixinit4me
  • 10 Answers
SOURCE: Washer fills continuously until it has overflown
I found this answer on Repairclinic.com. Hope it helps...
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Oct 28, 2007
  • 713 Answers
SOURCE: Water runs continuously tub never fills
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Posted on Apr 08, 2010
SOURCE: the washing macine, continues to
Your discharge hose is forming a syphon You need to arange a solution to break the syphon effect without causing an external leak such as a "T" piece at the top of the discharge hose with a valve. Shuts off under pressure (when pump is opperating) but opens when under suction (trying to syphon)
Posted on Oct 01, 2011
LG WD-1248RD. Why is it draining as rapidly as it fills?
Is it pumping the water out or draining?
Pumping sounds like an electonics problem, draing could be something wrong withe pump allowing the water to escape.
Sep 15, 2015 | LG Washing Machines
Frigidaire fdb1050rem0 dishwasher fills with water continuously. Control panel checks out fine. Float switch works but water inlet valve hums when door is closed.
Hello Darby Jones, I appreciate your post!
Based off the information you have provided your Frigidaire dishwasher is continuously filling with water. Sounds like you may have an issue with your water inlet valve. Typically, replacement of the valve is not a simple DIY job. I would recommend reaching to a professional to have a proper diagnosis completed to avoid any unnecessary part purchases. -Matt
Oct 30, 2014 | Dishwashers
Water continuously drains and fills, and never gets particularly high
You will need to check you washer drain hose and make sure it is only inserted into your house drain pipe in the wall no deeper than 4-6 inches, alternately your house drain needs to be as high as the top of the washer lid. Be sure to secure your drain line from the washer to one of the water shut off fittings with a zip tie. You are most likely experiencing a siphon action because the washer hose is inserted too deep in the house drain. Pleazer Appliance...
Apr 17, 2014 | GE GTUP270EMWW Washer
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer turns on and stays filling water and does nothing else
If your machine fills but does not start the agitation cycle, the limit switch which detects that the lid is closed is probably defective. (Same as when the machine is washing, but you open the lid and it stops.) It's an inexpensive part to replace.
Aug 31, 2012 | General Electric Washing Machines
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Whirlpool Clothes Washer Water Level...
The side container where the bleach goes is filling up with water after every wash
It is clogged, water flows into it to rinse the bleach out. If it becomes clogged the water just fills up and stays there. If you have any problems feel free to reply.
Please rate my solution if it was at all helpful to you.
Thanks, Repairman45
Dec 18, 2010 | Whirlpool GSX9750 Top Load Washer
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
