Viessmann boiler fault code - Heating & Cooling
What can I prevent fire
You can prevent fire by many ways.
Do not operate while it has the chance to got fire. IT is the first measure.
Sep 15, 2016 | Viessmann WB1B-26 Vitodens 100-W Gas Fired...
Furnace wont run after running
There are a few posibilities:
1) the oilfilter needs cleaning
2) your pressure reduction bore needs to be changed
3) there is still some air left in the oil-tubes coming from the tank and leads to your burner
The best solution is to call a technician, he'll fix the problem in no time and while he is at it, perhaps he could perform a maintenance
May 29, 2013 | Heating & Cooling
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Jan 31, 2012 | Heating & Cooling
Glowworm 24hxi combi boiler fault codes
it's an ignition fault (lockout) failed to light.
cause:
no gas
insufficient gas
incorrect gas valve adjustment
electrode ignition lead defective
electric igniter defective
check air inlet duct
check connections to igniter unit.
most common cause is igniter is defective (looks like a spark plug)
if you can hear a clicking when boiler goes to ignite, then it will be igniter at fault (no spark), check lead going to igniter (for any deterioration, looks like a ht lead). if all ok. change igniter.
hope this helps?
Jan 22, 2012 | Kitchen Ranges
Ariston Gas Boiler error code E02 what is the problem. No other boiler specification on the type of boiler.
i belive you have a ariston microgenus 2,from memory thats the fault code for low water presure,you need to re-presurise to 1 bar
Nov 27, 2009 | Ariston Technologies AWD 121
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
