Question about Keurig Platinum B70 Coffee Maker
Water pump makes a lot of noise when pulling water from tank
    New Friend:
    Problem Solver:
  • 8 Answers
You may need to descale the coffee machine... Use white vinegar and put into reservoir and run until reservoir is as empty as it will get. Fill with water and run to clear....I do this twice to make sure the vinegar odor is gone.
Posted on Nov 17, 2013
Water not pumping from the tank
If the pump is primed, water will come out of the tank when the pump is running. It make take a little time for the tank to fill, but you should hear the pump making some noise. An un-primed pump just makes a motor noise, not very loud.
Aug 12, 2015 | Plumbing
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
I have a ideal mexico boiler
you have sludge in your in your rads need a rad flush to clear it out .
Mar 02, 2013 | Heating & Cooling
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
Have a squeal and lost some antifreeze but did not over heat. I am wondering if this could be the water pump going bad are what?
Remove the belt. Then pull/push and spin the water pump pulley. If it has lots of play its likely the pump. But I've also had the idler wheel / belt intensioner pulley make noise.
Jan 09, 2011 | 2005 GMC Envoy
Loud grinding noise from unit when flushed like
take the pump out and haul it outside and spray it off and check in the bottom of the pump to make sure there isn't anything stuck in there. then shop vac the bottom of the tank out to make sure there isn't anything funky in there that would get clogged in the pump. sometimes the out let line gets clogged as well you can buy a drain king ( it's a rubber deal that hooks on the end of a hose and when you turn water on it swells up and sprays water out) then stick it in the outlet pipe and let her rip and see if it lets the water through.
Jul 28, 2009 | Saniflo & Saniplus& Macerator Pump
Well-Rite WR240R makes loud noise every time water flows into it
Tank may be air bound. There is an air valve on top of tank. Take cap off and depress valve momentarily. If water comes out of valve, the bladder is torn, and new tank is needed. If no water comes out, check the pre -charge pressure of tank.
First, run water in house and take note of the on-off pressure of your pump. There should be a water pressure gauge on the water line going into the tank. Take note of the cut on pressure and cut off pressure. Most well systems typically operate at 20-40, 30-50 lbs of pressure. Next,shut off electric to pump. Drain all water from tank. Take a tire gauge and check air pressure of tank. The static or pre-charge pressure should be two lbs less than the cut-on pressure,i.e if your system operates at 30-50, then the pre-charge pressure should be at 28lbs. Adjust pressure as needed. A small air compressor is ideal to use if more pressure is needed.
Jul 15, 2009 | Plumbing
KUD101FKSS Kichen aid dishwasher does not work.
There are three tabs that are holding the whole assembly, accessible from the bottom...they need to come out. Only then you can remove or even move the assembly...
Apr 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Sounds like it the pump needs to be oiled...how?
sometimes debris makes it way into the propeller shaft housing making an extremely bad noise pull it apart clean it out and see if the noise stops remember always wash aquarium filters and parts with the water from the tank or pond it came out of or bacterial quality will be disrupted causing the inhabited to suffer
Sep 27, 2008 | Waterway Supreme Hi Flo Pump Dual Speed 2...
Changing fuel pump
Being a 94 truck, you can rest assured the pump is in the tank. As for the pull bed, or drop tank question, it is up to you. I always pull the tank on every vehicle, unless someone has cut an access hole through the top of the body. There are a lot of people with a fuel pump change in their future, because the oil companys have changed the additives they put in the fuel we use, and it eats the seals in the old pumps. (they don't want you to know that) It is a lot easier to change an in tank pump than most people make it out to be. (Ah laziness) Hopefully the tank is low on gas, or empty, or it is gonna be really heavy.
Jul 01, 2008 | 1994 Chevrolet K1500
Keurig Platinum B70 Coffee Maker Logo
209 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
