Question about VeriFone Computers & Internet
Battery won't charge
When i plug in the terminal, the battery icon shows that it isn't charging. I've left it plugged in for a couple of days now but it still doesn't charge.
    Sergeant:
  • 396 Answers
You may either need a new charger (test it for voltage with a meter or have someone else do it for you), or a new battery. Check the cable of the charger for breaks, kinks are cuts, which may cause it to stop working. Both are available online.
Posted on Oct 11, 2013
2 Suggested Answers
SOURCE: I have a Novatel MiFi 2352, and the battery does
You can do two things to determine if the battery is dead:
  1. Use a USB charger to try to charge your battery or
  2. Replace the battery with a new one. Unfortunately, I can't find cheap third batteries for your product.
Both items can be found on ebay or amazon.
Both solutions will cost you around US$20-30 each. It's up to you to see if it is worth the cost. But you will definitely know if your battery is dead or if it is the unit that's not charging the battery.
If you go for this solutions, the outcome will definitely be a Win situation for you. Either you will have replaced the battery (if the battery is dead), or you will have two batteries and a charger (if it is the unit that is not recharging your battery).
Posted on May 13, 2011
Dell precision m6300 battery won't charge.
You say it's a new battery. Is the battery the same EXACT spec? Some aftermarket batteries don't work well with your laptop. The pin-out/connections may be incompatible. That said, in your BIOS is there a "Battery Learning" section.
Jan 04, 2013 | Dell Precision M6300 Mobile Notebook
Hello there, I own a toshiba c655-s5049 laptop about a year. When I connect a charger taskbar icon shows plugged-in, not charging and the front panel power/battery indicator lights green not orange. When...
Take some alcohol and a q tip and wipe the battery terminals and the terminals on the battery compartment. The laptop not getting a good connection with the battery
Aug 07, 2017 | Toshiba Satellite C655-S5049 Notebook
It wont charge consistently. In other words, its plugged in and the batter icon only shows a partial charge.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 06, 2011 | Dell Inspiron 1545 Notebook
When I plug my acer 7736/7736z Series laptop in to charge up the battery icon says 0% available (plugged in) not charging. After leaving it plugged in for an hour it still says the same thing. Any...
Try taking the battery out and running it. Some models will run without the battery, some won't. If it runs it's the battery that's shot. It is often the battery that goes as they only are good for a few years. I'm assuming you get into windows with it plugged in as you're seeing that it shows "0" left charge. Batteries will also get a much shorter life as it ages.
Jul 29, 2011 | Computers & Internet
I've had my acer aspire 5741z for about four
I think the problem is your battery pack..or to make sure contact a reliable and skilled computer technician handling the trouble personally is much better to make sure it will be fixed in no time..
Jul 05, 2011 | Acer Computers & Internet
I have an hp pavilion dv9350ea. Over a couple of years the battery became defective and I installed a new one. It showed 30% charge. I disconnected the charger to discharge the battery before re-charging...
I have to agree that the battery is defective or maybe it is NOT the correct one for your system, although it may be similar.
Did you buy the battery direct from HP a third party?
The AC adapter charger could be defective as well, maybe the defective battery ruined the charger.
I hope this helps.
Good Luck.
Mar 10, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
100 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
