Question about Ovens
My baumatic B0612SS oven outer door shattered and I need a complete replacement of the whole door. But I've looked everywhere online and know that it is obsolete. I really need the door, any help where I can find it?
Krazytech
  • 725 Answers
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Posted on Sep 29, 2008
barkencoa
  • 3463 Answers
SOURCE: main oven door outer glass panel shattered
I doubt you will get it cheaper any where, Zanussi is a bit of a closed shop.
If you can let me have the exact model no and the er number, I might be able to help you.
As for the reason it shattered, there are numerous reasons for this to happen, too many to go into, but it is a very common problem with cookers..
They do just go without any warning.
A cold kitchen could indeed be a factor, a badly fitting door is another factor, i could go on and on and on!!!!!
There is no one thing it can be put down to.
Plz let let me have the details I ask, and I will see what I can come up with.
Posted on Dec 12, 2008
SOURCE: I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Posted on Jan 15, 2009
philbran
  • 242 Answers
SOURCE: glass outer oven door panel
check sears parts.
Phil
Posted on Jun 10, 2009
SOURCE: The glass has shattered in my electrolux eou6330x door
It will be difficult to find just the glass, have it shipped and fumble with getting it into those factory sealed doors. The entire door can be purchased for right about $50. Click here to see. There is not a picture associated with this item, but it is the correct part number.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Feb 22, 2010
Testimonial: "thanks"
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
Oven door glass shattered
Replacement is likely not to be easy or cheap, but necessary.
Jan 10, 2014 | Tecnik Ovens
Hi, The inner glass on the door of my Belling 295 SS built in single oven has completely shattered after just preheating it (quite hot although!). I bought it in 2007 so it would be out of warranty. Can...
Hi.
You should not need to replace the complete door, just the door glass.
If you have not already done so, then I would suggest you contact the maker direct, they should be able to help you.
Try the web site.
WWW.BELLING.CO.UK.
Jan 11, 2011 | Ovens
Outer glass on oven door shattered, can i still use it
I wouldn't use it the temperature will get very high and the glass that is on the inside will be extreemely hot and could burn somebody badly if touched, Also the glass gets everywhere as they explode and if not completed cleared out may cut.
Nov 04, 2010 | Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Main oven door outer glass panel shattered
Dec 12, 2008 | Ovens
Nov 21, 2008 | Ovens
Sep 28, 2008 | Ovens
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
