Question about Lenoxx Electronics CD-102 Cassette/CD Boombox
The cd turns but no sound comes out, only a hum. Tried to take apart but screws are deeply imbedded and even after wd 40, they won't loosen. How do they expect anyone to be able to repair these things?
What does it mean when a washing machine motor hums and does not move until you push it?
Disconnect the power locate the motor. Remove the belt. Try turning the motor by hand that's a turn kind of hard lubricate both spindles with some WD-40 maybe even some penetrating oil then turn it as you spread if it loosens up you know it was a lubrication problem if not then you have to replace motor or the bel remove the belt. Try turning the motor by hand is a turn kind of hard lubricate both spindles with some WD-40 maybe even some penetrating oil then turn it as you spread if it loosens up you know it was lubrication problem if not then you maybhave to replace motor
Aug 02, 2015 | Washing Machines
Tip
I Want My (Digital) Rights!
In 1958, the Rocket Chemical Company realized that selling WD-40 for public use as a lubricant spray could be a very profitable endeavor. Today, WD-40 widely available in hardware and discount stores. There are five delivery systems for the product: WD-40 aerosel is the traditional delivery format; the WD-40 Smart Straw is a can with a permanently attached straw; the WD-40 No-Mess Pen allows you to use the product while on the run; WD-40 bulk/non-aerosol is offered in gallon and 55-gallon containers for large jobs; and the WD-40 Big Blast provides a wider spray pattern and larger can size.
Although WD-40 has a very distinctive smell, there is nothing dangerous in the product. The odor is simply the result of a fragrance added during the manufacturing process. The primary ingredients in the product are mineral spirits, liquefied petroleum gas, and mineral oil. The exact formula of WD-40 is a highly guarded trade secret, however.
For automotive repair, WD-40 has many uses. It can drive moisture out of the high- and low-tension electrical components of a motor engine and loosen nuts or screws. If you're trying to keep your car in top shape, WD-40 is also good for restoring and cleaning padded leather dashboards in vehicles.
Around your home, WD-40 can fix noisy door hinges, keep scissors working smoothly, loosen rusted screws, stop electric fans from squeaking, and lubricate the tracks in your windows to make them easier to open. Many people also report that spraying WD-40 on hand tools is a good way to prevent rust damage. Although it seems hard to believe, WD-40 is also a great household cleaning product. It is good for removing lipstick or tomato stains from your laundry. You can use it to remove stubborn duct tape residue, clean splattered grease off your stove, keep glass shower doors free of water spots, clean stainless steel sinks, and camouflage scratches in ceramic or marble floors. WD-40 will even take oil spots off concrete driveways.
dont remember to rate this tip...
thank you !
on Aug 16, 2010 | Audio Players & Recorders
Tip
What is WD 40 ?
on Aug 14, 2010 | Price Pfister 43-OOXC Bathroom Faucet,...
Spark electrode screws wont come off
use wd-40 or p.b.blaster to loosen but it is very (very) common to have to use a grinder or a roto-zip-saw metal cutting blade top cut-off an electrode bolt. even high-end grills are not using nigh-quality, expensive stainless for an electrode bracket or a screw.
Nov 07, 2013 | Dacor OB36 Gas Grill
Hi, I can't remove a toilet seat due to rusty bolts and nails holding it down underneath the toilet. I tried a bit of sandpaper, some WD-40 spray and tried loosening it with a wrench but the wings on the...
Sadly this is life. I've never had them come apart, they always break. New ones are inexpensive at your local hardware store. Some of them even have all the bolts as a kit.
Oct 20, 2013 | Cars & Trucks
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
Can the fan blade be easily remove on an Haier model HWR08XC1-T? I see a set screw on the fan, but there's no room to work and then remove. Sounds like a bushing is broken. Wobbles when running. Lot of...
Check and make sure the set screw is tight. Sometimes the screw will loosen and cause the problem you are describing.
However, to get the blade off - take out the set screw - spray some WD-40 in the hole - getting as much on in the hole (and on the shaft) as possible. Work the blade on the motor shaft (use a crescent to turn the shaft within the hub of the blade) and it should slide off the shaft.
If the blade is rusted on the shaft - do the above - but let it sit (with WD-40 on it) for awhile, i.e. several hours or even overnight if possible.
Note: sometimes there is a little disassembly (of the unit) you have to do to work the blade out.
Jun 07, 2011 | Haier HWR08XC1 Thru-Wall/Window Air...
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
1979 made Briggs & Stratton Model 130252 turns freely. Upon start up the motor begins to come up to speed and then starts screaming and dies. It sounds as if a brake is being applied or something is...
It sounds like the starter hub is binding on the crankshaft.take the starter housing off and look at the starter hub assembly,tap the starter hub off the crankshaft by using a block of hardwood,tapping it off in a counterclockwise direction,check the crankshaft section that the square starter hub rides on, clean it and follow up with a fine emery cloth,lube slightly with wd-40,be careful not to get wd-40 on the flywheel key area.If the starter hub comes apart and the ball bearings come out,dont worry you can put them back in after you screw the hub pack on crankshaft.
Aug 16, 2009 | Garden
Lenoxx Electronics CD-102 Cassette/CD Boombox Logo
50 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
Tony Mitri
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
