My Whirlpool Duet washer model # WFW9150WW02 stops about 3 mins into the wash cycle. It fills fine and drains when I put it on the drain cycle. It stops while it is agitating back and forth. If there are no clothes in the washer, the entire cycle works fine. Please help.
  • Richard Roth
    Richard Roth Oct 12, 2013
    Look for an article of clothing caught between the tub and the basket.
  • Chris Ramos
    Chris Ramos Oct 13, 2013
    Nothing there either.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Have you cleared the drain filter out?
Posted on Oct 11, 2013
  • Chris Ramos
    Chris Ramos Oct 11, 2013
    yes, the drain filter is clean. It won't advance from the slow agitation cycle to the faster spin cycle unless there are no clothes in it.
Was having same problem, removed front cover and cleaned filter and working fine with full large loads.
Posted on Nov 22, 2014
4 Suggested Answers
  • 662 Answers
SOURCE: Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
  • 1028 Answers
SOURCE: washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Posted on Sep 13, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Washer says fo6 what is the problem
if it will drain and spin o. k. you may have a bad main board.
Mar 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
262 people viewed this question
Top Washing Machines Experts
